Pocket path generated only on face depth if object is reversed or origin moved
PavloT
Postby PavloT » Mon Aug 17, 2020 11:06 am
I faced with quite annoying issue: in case if pad object created as reversed, pocket path will be generated only on depth of pocket face:
This pad has normal direction
This was created as reversed
The same if JOB origin moved to top of the PAD
I use such configuration because for my CNC I set Z0 to material top, so I expect all operations will be in negative depth (material pieces have variable thickness, so it is more easy to set 0 to top and find it with sensor, otherwise each peace must be measured, next this value added)
Freecad version: 0.19~pre2~202008100051~ubuntu18.04.1;
Current MASTER build (I have rebuild it on my host)
Not reproduces for FreeCad 18.4
reversed_pocket.FCStd
(31.89 KiB) Downloaded 30 times
normal_pocket.FCStd
(33.61 KiB) Downloaded 28 times
jmaustpc
Re: Pocket path generated only on face depth if object is reversed or origin moved
Postby jmaustpc » Mon Aug 17, 2020 11:23 am
Welcome to FreeCAD. :)
Probably make no difference but I wonder if the problem is there in the FreeCAD 0.19 from the daily PPA?
Could you attach a simple as possible file that demonstrates the matter?
GeneFC
Postby GeneFC » Mon Aug 17, 2020 2:27 pm
I do this also, and I never see that type of problem. I suspect it is merely a case of incorrect height parameters in the Pocket operation. FreeCAD provides defaults, but they are not always correct. It is easy to override the default parameters with correct parameters.
We need an FCStd file.
Gene
PavloT
Postby PavloT » Mon Aug 17, 2020 2:42 pm
Here are two files.
(32.43 KiB) Downloaded 31 times
contains issue.
This is only for daily PPA or latest sources. Issue does not exists in stable version.
I test daily version because I really like "Profile open edges" and "Pocket extensions" features implemented in FreeCad 19.
I think it is related to issue #4411, but cannot find root cause yet (still new with FreeCad code). If anyone have idea what should I check - I can try to debug it.
normal_pocket.FCStd
GeneFC
Postby GeneFC » Mon Aug 17, 2020 3:26 pm
I tried your files, and yes, there is a problem. If I set the start height to 20 mm without changing anything else the pocket works correctly.
Of course that should not happen. It does not appear related to bug #4411.
[Edit] Works OK with
OS: Windows 7 SP 1 (6.1)
Version: 0.19.22111 (Git)
Hash: cb2099aa6bb287a8d7843eb70684cce79bdef26b
Python version: 3.6.8
Qt version: 5.12.1
Incorrect with
Version: 0.19.22261 (Git)
Hash: 1c432fd6170b7904592a224194e42d3c566707a6
Qt version: 5.12.1
Gene
GeneFC
Postby GeneFC » Mon Aug 17, 2020 4:36 pm
I have done a bit more digging, and it appears the problem came from the "fix" to bug #4411.
In particular,
Merge pull request #3763 from Russ4262/PocketShape_fix_t4411
merged on August 4.
I have not worked through the exact error, probably a typo or reversed sign.
Gene
umill
Postby umill » Thu Sep 10, 2020 9:38 pm
I would also like this bug fixed for my projects as well.
I noticed that the bug persists for version FreeCAD_0.19.22366-Win-Conda_vc14.x-x86_64 and would like to pitch in to fix it.
Unfortunately, I am having an error compiling from source with Cmake not finding Boost and am in the process of figuring this out. But any guidance on how to help out would be appreciated.
Postby chrisb » Thu Sep 10, 2020 10:54 pm
Great to see a helping hand. Much of Path is written Python, so you don't necessarily have to compile FreeCAD.
GeneFC
Postby GeneFC » Thu Sep 10, 2020 11:16 pm
I am pretty sure this is 100% Python. I tried to dig into the problem, but I quickly got lost in all the imports and links to other files.
I suspect this is a very simple error, if only one can find it.
Gene
umill
Postby umill » Sat Sep 12, 2020 1:46 am
Thanks! I didn't realize we didn't need to compile the code for this.
I finally managed to get the Cmake errors figured out and it is compiling at the moment.
Sorry for the newbie question(first time contributing :D ), but for the python files are all changes to the source loaded if we just restart Freecad?
