thread milling?
Re: thread milling?
Rolled threads are stronger than tapped threads. Bicycle spokes have rolled threads for that reason. The thread o/d ends up bigger than the spoke diameter since nothing is removed.
Often, special high tensile bolts , like for con-rod caps are rolled threads.
High quality, precision ball-screws are rolled not ground.
Re: thread milling?
The so-called "form taps" are not the same as "rolled threads". The material is moved rather than cut in both cases, but the rolled threads will be stronger than the formed threads. They also have a much better profile. The form taps leave a strange profile that is not the typical vee-shape.
The best ball screws are definitely ground. Rolled screws are cheaper and less accurate. As an example here is an excerpt from the Nook Industries catalog.
Nook is one of the premiere ball screw manufacturers in the US.
Enough off-topic. Back to regular programming.
Gene
Nook uses the latest in CNC thread rolling technology and state of the art CNC induction heat treatment to
manufacture a rolled screw with accuracy approaching precision ground at a substantially lower cost.
They fill the need for applications that don’t warrant the expense for ground screws but still require more precise
positioning than that offered by commercial grade screws.
Gene
Re: thread milling?
Oops, got the ballscrew thing back to front . Thanks for the correction.
Re: thread milling?
This is the only place I can find anything that says "thread milling" so far, and I also have not used it, yet. Definitely going to be in the near future, though. I'm not sure if it's meant to be used with say a helix op? Whatever, it'll get figured out and become something that future noobs will take for granted. And I know you guys actively developing FreeCAD probably don't hear it enough, so thank you.
- Screenshot from 2021-09-19 23-43-49.png (101.34 KiB) Viewed 3503 times
BOOTSTRAPPY WORKSHOP - Where we do more with less
https://tv.gab.com/channel/lowellhouser
Re: thread milling?
I have not used thread milling, either, but I believe the helix is built in. The TM operation uses G2 and G3 codes, which already have helix behavior as part of their intrinsic functionality.
Try it and see.
Gene
Re: thread milling?
I can't at the moment.
(1)I've tried enabled experimental commands in preferences and I still can't find the icon for thread milling. Using .20
(2) I don't own a thread mill tool yet
(3) the tool I have in the que to buy does not fit the router I am currently using as a spindle.
(4) I just posted a vid on my channel (in my sig) explaining that the machine isn't rigid enough to handle aluminum, so I have to push up the scheduled overhaul of the entire machine.
The overhaul involves using the router to cut styrofoam patterns for use in Lost-Foam casting. The base of the machine is several layers of OSB glued together that has to be coated in epoxy top and sides while the aluminum castings are being processed. Then the whole thing has to be bolted back together with the new 2 1/4HP spindle that can take a 3/8 shank for the tool from McMaster(or 5/16, because the other option from Micro uses that), then I have to do the full shakedown tightening everything, dialing in the steppers, and then the tram.
After all of that, I'm hoping that the machine will handle cutting 4140 with a VERY conservative step-over and then single point threading for 1/2-28.
Hoping to have all of this in play by December. I'm sorry that I can't be more help, yet. It would be kinda cool to be the first on the internet with a vid doing this.
Re: thread milling?
I don't have a lathe. The workpiece is going to be over 12inches long. The machine-base is going to have a flanged hole installed in the front to allow for very tall objects to be cut vertically. It will accept a flanged plug. So the workpiece sticks up through vertically just enough for the new clamping system, something like an improvised mod-vice from NYC CNC. Designing the whole thing as an integrated system.
And besides, if This Old Tony can make a router that can cut a functioning sprocket out of 4140 roundstock for his mini-bike, I'm sure that I can fail spectacularly merely reducing a diameter to threading size.
Re: thread milling?
I'm certainly not good enough with Python to code this but thread milling is actually quite easy to wright gcode for by hand. I would think using G2 and G3 with some variables would do it.
Here's a good description form the Haas website.
https://www.haascnc.com/service/codes-s ... e=G02.html
Re: thread milling?
Hello,sliptonic wrote: ↑Sat Jul 10, 2021 11:14 pm It looks there's a specific class of threading tools that do this forming vs cutting action. Conventional taps and other tools have flutes and produce chips. these don't but can only be used on certain materials. Definitely a very different tool from a thread mill.
Interesting stuff. Today I learned.
maybe a little late. The form tap requires a bigger start hole than a tap that makes chips. It pushes material away instead of cutting.
The CAM side does it as posted by others like a rigid tapping operation.
Can a tension/compression head on a milling machine solve the movement coordination? Not sure about that, it might have problems to "start" properly.
