[RESOLVED] Path Pocket generating wrong code
falviani
Postby falviani » Wed Sep 16, 2020 2:01 pm
Hi All,
My setup:
OS: Windows 10 (10.0)
Version: 0.19.22452 (Git)
Hash: 5abb45f7cfc68eda94568ef92b2cb1d83acd1cb4
Python version: 3.6.8
Qt version: 5.12.1
(built from source 9/15/20 10PM)
Generating code for a simple pocket operation is ignoring the start depth and stepdown values; the initial z-axis value is the finish value. The design is not complex:
I believe this is a bug. I've attached the freecad file and the generated gcode (extension changed to .txt so I could attach it) for examination. If I've done something stupid please let me know as soon as possible...
Thanks in advance,
Frank
SprayPaintRack_v2.txt
(37.76 KiB) Downloaded 9 times
SprayPaintRack_v2.FCStd
(84.56 KiB) Downloaded 10 times
GeneFC
Re: Path Pocket generating wrong code
Postby GeneFC » Wed Sep 16, 2020 3:03 pm
I have not yet compiled the latest fixes, but something I noticed in your file is that the "Finish Depth" is set incorrectly. This should be the final step-down value wanted, not the final depth. Usually no more than 0.1 mm or 0.2 mm. In many cases it is just zero.
Gene
falviani
Postby falviani » Wed Sep 16, 2020 3:20 pm
Hi Gene,
Thanks for pointing that out :D Once I had the start depth at 0 and the finish depth at 0 I got what I was expecting. Can't see the obvious some times...
-Frank
Re: [RESOLVED] Path Pocket generating wrong code
Postby chrisb » Wed Sep 16, 2020 4:45 pm
It would be easier if it was named Finish Step Down.
sliptonic
Postby sliptonic » Fri Sep 18, 2020 3:36 pm
I agree. Please make a feature request so this doesn't get lost
Postby chrisb » Fri Sep 18, 2020 5:52 pm
