harshmacwan wrote: ↑Mon Jun 07, 2021 4:00 pmAmazing, This worked and GCODE was generated.
I have attached the code here.
Thanks a ton Adam for your help and contribution towards Open source CAD/CAM. Now me and my friends are on the track towards making a freecad work bench and seamless 5 axis generation. I will be very happy if you provide your suggestions.
Harsh
(add tool offset moves from home ect...) G43 H2 G21 G90 G93 G0 Z50 M3 S21390 G0 X-0.002905 Y0.010889 Z0.029513 A94.831881 B1.287190 G01 X-0.001804 Y0.011125 Z0.029510 A94.935841 B0.798657 F324.124272 G01 X-0.000680 Y0.011250 Z0.029508 A94.990894 B0.300746 F324.124272 G01 X0.000450 Y0.011261 Z0.029505 A94.995955 B-0.200153 F324.124272 G01 X0.001576 Y0.011160 Z0.029503 A94.951004 B-0.698973 F324.124272 G01 X0.002686 Y0.010946 Z0.029500 A94.856515 B-1.190664 F324.124272 G01 X0.003768 Y0.010622 Z0.029498 A94.713469 B-1.670248 F324.124272 G01 X0.004812 Y0.010192 Z0.029495 A94.523341 B-2.132890 F324.124272 G01 X0.005806 Y0.009660 Z0.029493 A94.288087 B-2.573943 F324.124272 G01 X0.006742 Y0.009032 Z0.029490 A94.010121 B-2.988992 F324.124272 G01 X0.007610 Y0.008314 Z0.029488 A93.692288 B-3.373917 F324.124272 G01 X0.008401 Y0.007514 Z0.029485 A93.337841 B-3.724909 F324.124272 G01 X0.009108 Y0.006639 Z0.029483 A92.950220 B-4.038673 F324.124272 G01 X0.009725 Y0.005698 Z0.029480 A92.532487 B-4.312639 F324.124272 G01 X0.010245 Y0.004701 Z0.029478 A92.089632 B-4.543422 F324.124272 G01 X0.010662 Y0.003657 Z0.029475 A91.626090 B-4.728820 F324.124272 G01 X0.010974 Y0.002578 Z0.029473 A91.146452 B-4.867080 F324.124272 G01 X0.011176 Y0.001474 Z0.029470 A90.655499 B-4.956891 F324.124272 G01 X0.011268 Y0.000355 Z0.029468 A90.158091 B-4.997413 F324.124272 G01 X0.011248 Y-0.000767 Z0.029465 A89.659176 B-4.988272 F324.124272
Hi Adam,
Now we are moving ahead with the project and while creating spline we are facing some issue.
We are getting a Broken Pipe issue with the socket connection while generating the gcode for spline. I have attached here the snap of that along with the file contains coordinates in the format of (x y z u v w). I have also attached the modified version of hellowolrd.py to read from the file and a freecad snap to see the spline with tool angle.
Let me know if you have any idea how to resolve the issue. Also, would it be possible to explain the process of how to debug the Modelica model so that we can get to know the exact issue?
Regards,
Harsh
