sliptonic wrote: ↑Fri Oct 30, 2020 9:28 pm
I can't duplicate this with either toolbits or with legacy tools. The only way I can duplicate is if I open the tool controller edit dialog from the Job Tools tab, change the spindle speed and click 'ok' without exiting the spindle speed field. That might be a legit bug to fix but please confirm that this is what's happening before I touch code.
Hah - this is a sneaky one.
On my Mac (version info below), I can still reproduce the issue reliably if I either
- click OK directly OR
- use Tab to navigate to the spindle direction drop-down listbox before closing the dialog OR
- switch the focus to the tool number "spinner" box in the top right of the dialog before closing it OR
- switch to the "Tool" drawer at the bottom of the dialog before closing the dialog.
If, before closing the dialog, I place the focus into another text-ish input box on the "Controller" drawer (Controller name or any of the feed rate entry boxes), the issue does NOT appear. If however I switch to one of the text-ish input boxes on the "Tool" drawer, the issue still appears.
I faintly remember from way back when I was still doing Qt stuff that there might be a difference between OSes - let me double-check on my Windows workshop machine.
EDIT: Not this time, behaves exactly the same on my Windows system, even with 0.18.
OS: macOS 10.15
Version: 0.19.22846 (Git)
Hash: 1f46b72491a0008384a6db4f2615a656249f6f08
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
