The simulation of this 3D surface shows unexpected Z motion in both '0' and '180' directions, irrespective of speed/accuracy settings. It appears the g-code is correct, although haven't tried an air cut on the mill yet. As a general rule is it better to rely on the wireframe representation of an operation than the simulation animation?
OS: Windows 10 (10.0)
Version: 0.19.23074 (Git)
Hash: 74b866ed3022fd1452c534dae31a721bcc668f2f
Python version: 3.8.6
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Locale: English/Canada (en_CA)
3D surface simulation accuracy
- 3D_surface_simulation.jpg (347.57 KiB) Viewed 1578 times
Re: 3D surface simulation accuracy
Definitely!
Both seem great tools, thank you. You've probably deduced I'm on a steep learning curve (but making rapid progress).
File attached. It appears to go seriously awry when step-over is >50.
- Oloid.FCStd
- (51.51 KiB) Downloaded 77 times
Mission accomplished...the g-code was correct despite the simulation suggesting otherwise. NC Viewer was a good sanity check tip.
- mn00n_3DSurface.jpg (282.81 KiB) Viewed 1345 times
Nice!
Thanks for sharing.
Russell
Thanks for sharing.
Russell
Off topic but related, updating the path simulator could be a potential project to put a bounty on...?
