Selecting multiple path faces
VERS 0.19 23258 GIT
Yet another Fusion360 convert. I just don't have reliable internet to continue to use it among the many other reasons.
Is there a way to select multiple faces at a time for a pocket feature like a chain select tool?
Is there a way to reselect a previous base geometry selection when adding a new tool to the same previous path?
I need to pocket this with 3 tools and it takes forever to select all the faces each time.
- cog center pocket.jpg (282.64 KiB) Viewed 2035 times
Re: Selecting multiple path faces
Finish loop tool, works for edges and faces, should do what you want.
Welcome to the FreeCAD forum, Geckocycles !
When you create subsequent operations, the Base Geometry section will have a selection menu and `Import` button above the feature list area. Select from which op you wish to import, click the button, and all the selected geometry from that op will be imported to the current list, so long as it meets requirements for the current op.
See the attached image.
Again, welcome.
Russell
Yes, there is. In your screenshot, the operation being modified is the first operation in your Job. For this reason the import feature is unavailable.geckocycles wrote: ↑Tue Dec 15, 2020 3:52 pm VERS 0.19 23258 GIT
... Is there a way to reselect a previous base geometry selection when adding a new tool to the same previous path?
Again, welcome.
Russell
- Import base geometry feature
- Snip macro screenshot-e8d2f4.png (182.91 KiB) Viewed 1992 times
I am struggling to get Path SelectLoop to react to faces, no mention of this feature in the wiki either. What am I missing?
Need help? Feel free to ask, but please read the guidelines first
Don't think you're missing anything, other than a properly functioning loop selection tool. I remember seeing that error before, although in my case all faces ended up being selected. Had forgotten about it - would you mind filing a bug? That way sliptonic has a reminder to hunt me down
I cannot see it clearly from the image, did you select two faces?
Yes, in the image 2 sides of nut is selected. I have tried many different parts and not made a complete loop with faces.
Sure!mlampert wrote: ↑Tue Dec 15, 2020 10:05 pm Don't think you're missing anything, other than a properly functioning loop selection tool. I remember seeing that error before, although in my case all faces ended up being selected. Had forgotten about it - would you mind filing a bug? That way sliptonic has a reminder to hunt me down
Long time since i posted a bug, seams to be a it more involved these days, will read up on it before i post the bug.
Looks like the error message is displayed both on success and when the operation fails.
Attached a file for demonstration purposes.
Selecting any two of the faces not co-planar and not top and bottom. Before issuing the Path SelectLoop ,gives the same result. All faces except co-planar and top and bottom gets selected.
Would expect command failure if a face from each level was selected. And full level selection if two faces from same level was selected.
Please verify if you observe the same issues.
FreeCad-Daily
OS: Ubuntu 20.10 (KDE/plasma)
Version: 0.19.
Branch: unknown
Hash: 1bc39542d33196d585630b3a943f93b269c4f55c
Python version: 3.8.6
Qt version: 5.14.2
Coin version: 4.0.0
OCC version: 7.4.0
FreeCad-Daily
Version: 0.19.
Branch: unknown
Qt version: 5.14.2
Coin version: 4.0.0
OCC version: 7.4.0
- closed_loop.FCStd
- (22.47 KiB) Downloaded 42 times
Thanks for the welcome.Russ4262 wrote: ↑Tue Dec 15, 2020 8:32 pm Welcome to the FreeCAD forum, Geckocycles !
Again, welcome.
Russell
This is a part I made in Fusion and imported as STEP.
I created body.
I created a tool path with the first tool and looks good except for step down which cut to full depth. No problem with this part but I will have to figure that out later.
Imported Pocket_Shape to new tool Op and there is now lost geometry even in my model. Couldn't recover or see the issue so I started over. Lost the hole completely in the original model but the pocket profile is still there, just no extrusion shown. I just don't see a break in the chain.
Trying to watch more vids but internet keeps going out. Burning up data using phone as hotspot to reply so sorry for the late one.
