[SOLVED][Bug] Postprocessing error 'Cannot access attribute 'Proxy' of deleted object'
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19. Daily
Branch: unknown
Hash: e8566f22bbeb0b7204e3c45519d0963e8881100b
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.1
If I want to postprocess from more than one .FCStd file in one FreeCAD session, the following error is thrown at me:
13:19:23 Running the Python command 'Path_Post' failed:
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathPost.py", line 396, in Activated
(fail, rc, filename) = self.exportObjectsWith(finalpostlist, job)
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathPost.py", line 211, in exportObjectsWith
gcode = processor.export(objs, filename, postArgs)
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathPostProcessor.py", line 100, in export
return self.script.export(obj, filename, args)
File "/usr/lib/freecad-daily/Mod/Path/PathScripts/post/linuxcnc_post.py", line 197, in export
job = PathUtils.findParentJob(obj)
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathUtils.py", line 444, in findParentJob
if hasattr(i, 'Proxy') and isinstance(i.Proxy, PathJob.ObjectJob):
Just got the error with the two attached FCStd files, but could have been any other file combination as well - the error is thrown at me for a while now.
I just checked and the error is independent of the used postprocessor (checked for linuxcnc, dxf, grbl and two of my own postprocessors).
Branch: unknown
Qt version: 5.12.8
OCC version: 7.5.1
- Sound_Fillet.FCStd
- (182.42 KiB) Downloaded 41 times
- A_Single_Bottom.FCStd
- (86.38 KiB) Downloaded 41 times
Re: [Bug] Postprocessing error 'Cannot access attribute 'Proxy' of deleted object'
I just tried your files, and I did not see any problems as described.
I did find two issues when I tried to simulate in Camotics. One of the output files has all feedrates set to zero. Another has a problem with improperly defined arcs in which the radius and endpoints of the arcs do not match correctly. Neither of these problems would be the cause of the "proxy" error.
If I was to guess, I would say that you have done some manipulation of the Job file(s), perhaps with additions and deletions. I have found that "cancels" and "deletions" sometimes lead to the type of error in the title of this topic.
I suggest that you save the files, close FreeCAD, and reopen the files.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Gene
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Gene
Thank you Gene testing!
When I reopen FreeCAD, postprocessing always works again. Its not about just getting the files postprocessed, but eliminating this error for an improved workflow.
The 'arc' problem comes from the linuxcnc_post. If working in G17, many millcontrols (including linuxcnc) do not like 'K' values in the G-Code. The particular Job contains some arcs in G18.
- sliptonic
I have seen this bug and I hate it.
Once the bug occurs, you can't do anything useful in Path. Postprocessing doesn't work on any file. The bug isn't specific to the file. If you close and reopen the document, the problem remains. But if you close and restart FreeCAD, it goes away.
So there's something that happens in the GUI that set up the condition. What we need is a reproducible set of step to trigger it.
Seems you can readily reproduce this issue. Could you change PathUtils.py from
return i
try:
return i
except:
print("object: {}", i.Name)
raise
Just did a little bit of try and error and now I have a consistent way of reproducing the error with the attached files:
1. start new FC session
2. open both files
3, Postprocess the job in one of the files (does not matter in which)
4. save and close the file you just postprocessed
5. postprocessing the second file throws the error
Is that reproducible for anyone else?
with the changes in PathUtils.py the error looks like this:
19:42:03 Running the Python command 'Path_Post' failed:
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathUtils.py", line 448, in findParentJob
Cannot access attribute 'Name' of deleted object
2. open both files
- Test_proxyerror_2.FCStd
- (110.19 KiB) Downloaded 36 times
- Test_proxyerror_1.FCStd
- (24.66 KiB) Downloaded 33 times
Afternoon,
I am able to reproduce with:
1. Start FC
2. Open one of files provided in this thread.
3. Load PathWB
4. Select a job and post-process (EDIT: select linuxcnc post from GUI list) and save output
5. Close file, with or without saving.
6. Open another file from this thread
7. Select a job and post-process (EDIT: select linuxcnc post from GUI list) and save output
8. Raise eyebrow at the error.
Making progress on identifying the offending critter, and I found a separate bug while looking for this critter, related to job selection in PathPost module.
Have to step away from FC machine for a while. Will continue and report back when I am able.
EDIT: Updated my error reproduction procedure above. Getting different results if I don't change post processor selection in GUI list, leaving on `centroid` and clicking OK.
Russell
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Me again.
Performing some more testing. Making more discoveries on producing the error and when/where it occurs. Will report back.
Russell
Russell
- sliptonic
I don't understand why this is suddenly happening. When the postprocessor tries to look up the job by looking for for the parent of the objects to be posted, it's seems to be trying to find the job of the document that was closed.
I don't understand it but it's easy (and a very good idea) to avoid it.
In the linuxcnc_post.py file,
comment out this line: https://github.com/FreeCAD/FreeCAD/blob ... st.py#L197
Also comment out https://github.com/FreeCAD/FreeCAD/blob ... #L201-L212
This entire section is deprecated because the job doesn't have a 'MachineName' or 'MachineUnits' property anymore and hasn't for a very long time.
This is the only reason the postprocessor is trying to look up the job. It's an entirely worthless call and it's being made for every object being post processed!
The change will have to be made for every postprocessor.
Works perfectly with the 'worthless call' commented out. Thank you all for your help!
