Postprocessor for Stepcraft 420 + UC-CNC + UC100
- PapaAtHome
For some time I've been working with a Stepcraft 420 machine using UC-CNC software for the GCode and a UC100 communication device.
For this line I have created a post processor in FreeCAD.
More correct to say is that I changed the linuxcnc_post.py script done by sliptonic.
While I did quite a few changes I cannot claim copyrights, only be the maintainer for my version.
UC-CNC has one outstanding missing feature (next to some other minor ones)
It does not support G20/G21 codes so changing 'on the fly' between inches or mm is a no-no.
I tested this version on FreeCAD 0.17 but also have used it on 0.18 and 0.19
Have fun, if there are any questions, drop me a message and I will see what I can do.
Kind regards,
Andre.
Kind regards,
Andre.
- Stepcraft420UCCNC_post.py
- (36.22 KiB) Downloaded 80 times
Kind regards, Andre.
Re: Postprocessor for Stepcraft 420 + UC-CNC + UC100
Thanks for contributing. Do you mind creating a pull request?
I don't think it's a serious restriction. You either model in inches or metric, but hardly ever in both. And it is no restriction at all if you generate the code anyway.PapaAtHome wrote: ↑Tue Mar 23, 2021 2:19 pm It does not support G20/G21 codes so changing 'on the fly' between inches or mm is a no-no.
- PapaAtHome
I don't mind but how should I create a pull request? (I have no previous experience with that.)
(edit: Working on a pull request. I'm having a look at https://forum.freecadweb.org/viewtopic.php?t=3781 for this.)
True, I fully agree. But to be sure I included checks in the post processor.chrisb wrote: ↑Tue Mar 23, 2021 3:38 pmI don't think it's a serious restriction. You either model in inches or metric, but hardly ever in both. And it is no restriction at all if you generate the code anyway.PapaAtHome wrote: ↑Tue Mar 23, 2021 2:19 pm It does not support G20/G21 codes so changing 'on the fly' between inches or mm is a no-no.
By the way, there is more comment than code in the script and a substantial part of the code is about checking conditions.
Andre.
Kunda1, can you help? Git and I havent really made friends yet.PapaAtHome wrote: ↑Tue Mar 23, 2021 4:06 pm I don't mind but how should I create a pull request? (I have no previous experience with that.)
Kunda1 wrote: pinged by pinger macro
- PapaAtHome
Working on it. I'm a SVN man and not particularly good friends with Git as well.chrisb wrote: ↑Tue Mar 23, 2021 4:22 pmKunda1, can you help? Git and I havent really made friends yet.PapaAtHome wrote: ↑Tue Mar 23, 2021 4:06 pm I don't mind but how should I create a pull request? (I have no previous experience with that.)Kunda1 wrote: pinged by pinger macro
So to switch between imperial and metric the software needs to be restarted with a different machine definition instead of using G20/G21 at the head of a program ? An unusual limitation but probably no bother to most users. I would be a bit surprised if UCCNC doesn't error/alert on unknown gcodes
In any case it's good to have the post check for those codes.
For English help on youtube check out Joko Engineering or Mango Jelly Solutions.
Look for recent videos, this software is updated at a rapid pace.
So am I!
- PapaAtHome
Not realy, UC-CNC has the 'normal' response of ignoring the GCode in total.jbraun wrote: ↑Tue Mar 23, 2021 4:37 pm So to switch between imperial and metric the software needs to be restarted with a different machine definition instead of using G20/G21 at the head of a program ? An unusual limitation but probably no bother to most users. I would be a bit surprised if UCCNC doesn't error/alert on unknown gcodes
But if you start using inches in stead of mm you will get something that is 25 times bigger than what you expected.
That is why I try to check and at least give a warning.
- PapaAtHome
I was using https://forum.freecadweb.org/viewtopic.php?t=3781 as a guide for my actions and this is what I did.chrisb wrote: ↑Tue Mar 23, 2021 4:22 pmKunda1, can you help? Git and I havent really made friends yet.PapaAtHome wrote: ↑Tue Mar 23, 2021 4:06 pm I don't mind but how should I create a pull request? (I have no previous experience with that.)Kunda1 wrote: pinged by pinger macro
Since I'm doing this for the first time I will give full details on what I did. If I missed something or did the wrong thing, give me a note.
Created a public git repository at https://github.com/papaathome/FreeCAD_work/ and filled it with pull from https://github.com/FreeCAD/FreeCAD
Created a branch https://github.com/papaathome/FreeCAD_w ... tprocessor from the master branch.
Then I created a local sanbox on my PC and cloned the uccnc_postprocessor branch.
I added the post processor script and in the process renamed it 'uccnc_post.py' since the 'Stepcraft' part in the name is totally irrelevant.
This I committed and pushed to git hub.
The git hup site shows my last action and I can find uccnc_post.py in the branch.
The next step is not clear for me. What must I do to initiate a pull request?
Better instructions are on our wiki page called Github. Looks like you are 90% there.
All you need to do is:
1. Make sure you're in the correct branch. Changing branches if need be: 2. Making the Pull Request against FreeCAD master branch 3. Fill out the Pull Request template add a summary of your commit, link to the forum discussion and add an 'X' in between the square brackets for steps you have completed. The markdown format must be precise.
4. Press the 'Create Pull Request' button
- [x] (correct)
- [ x] (incorrect)
- [x ] (incorrect)
[x] (incorrect)
-[x] (incorrect)
