Ticket #4602 - Vcarve Cutting Air
Colin_W
Post by Colin_W »
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.19.24276 (Git) AppImage
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Hi
I'm having a problem here with Vcarve. The attached image shows the result of Vcarve vs Engrave. Engrave performs as expected an honours the depth settings. Vcarve stubbornly sits above the surface cutting air. Changing depth settings does not change the height of the path.
In order to use the generated path I would have to set the material surface to approximately 1mm on the cnc.
It looks like a bug, have I missed something simple?
Colin
vcarve-test.FCStd
(101.68 KiB) Downloaded 40 times
Reason: Added ticket number to thread title
mlampert
Re: Vcarve Cutting Air
Post by mlampert »
confirmed, this is a bug - can you file an issue with the bug tracker?
Colin_W
Post by Colin_W »
Thanks for the quick response.
issue #4602 raised
Re: Ticket #4602 - Vcarve Cutting Air
Post by Kunda1 »
Ticket wasn't assigned to Path. Now it is. Updated thread title to reflect ticket number.
baum
Post by baum »
For me the change from this pull request fixed it: https://github.com/FreeCAD/FreeCAD/pull/4680
The path still starts in the air, but has the correct depth and thus goes into the material to the extend needed.
The start point above the part is due to the path calculation being based on a pointy tip of the tool, but the tool definition having a tip diameter given, resulting in a z height offset.
monkeydog
Post by monkeydog »
Neat thanks ! been guessing the offsets until now, much better results.
Screenshot from 2021-06-20 21-19-21.png (559.43 KiB) Viewed 2270 times
(Completed job image added to original Draft ShapString vcarve)
baum wrote: Thu Apr 08, 2021 12:37 pm For me the change from this pull request fixed it: https://github.com/FreeCAD/FreeCAD/pull/4680
rmeissn
Post by rmeissn »
The mentioned fix is still missing in FreeCAD 0.19.2, but is included in the current weekly build of FreeCAD 0.20. I hope it will be included into a future FreeCAD 0.19.3 release, as V-Carve is currenty broken in 0.19.2.
I noticed another (maybe linked) bug, which is present in 0.20 (and also 0.19.2). When doing the carving, the tool moves up and down between the ideal carving path and the (I guess) safety hight a lot - making the carving much slower than it needs to be. I'm not entirely sure, as my used font size is pretty small, but I think this sometimes produces little carving artifacts. I've used a 20° V-bit and a small font size, which produced the attached path and carving. You may see those artifacts inside the "g"s of "Energienutzung". These are less visible after a cleanup, but still there.
Bildschirmfoto von 2021-10-24 21-00-49.png (35.96 KiB) Viewed 1568 times
