Like Subject say, i noticed a strange behavior of the 3D Surface Op, using the Patern option ZigZag.
If i work with an Step Over of 100 or 50 i get the expected path.
If i change the Step over to something else, the path looks like this:
The amount of the jumps differs, depending the value of the Step Over.
If i select the flat area above of the "bumps" to, i get a path without any jump, no matter of the value for the Step Over.
If i deselect Boundary Enforcement, i get also a Path without jumps (but the path dosn't fit to my router then...).
Made with:
OS: openSUSE Tumbleweed (KDE//usr/share/xsessions/plasma5)
Version: 0.20.24612 (Git) AppImage
Hash: f525904c1be10a0f55aa3502151c2c55e5054259
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
The File is to big to attach it, if someone wants to have it, i'l make smaller example (which hopefully shows the same behavior... )
Strange behavior of 3D Surface Op
Gruß Herbert
Re: Strange behavior of 3D Surface Op
Afternoon.
No problem. I created a similar file. I was able to reproduce the bug. The bug appears to be related to the `Optimize Step Over Transitions` feature. Also, I notice an oddity - the paths are without error when the Step Over is a multiple of 25%. You mentioned things are okay at 50 and 100 percent. My tests show 25 and 75 percent Step Over are okay as well. We likely need to file a Mantis ticket for this.
My tests use a 3mm ball endmill and ZigZag cut pattern with single-pass layer mode.
Source file attached for reference.
Russell
OS: Windows 10 Version 2009
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Russell
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
- battery_case.FCStd
- Source file
- (126.17 KiB) Downloaded 9 times
- ZigZag, 25% Step Over, 0.5 mm Sample Interval, and Optimize StepOver Transitions set to True
- Snip macro screenshot-798314.png (307.88 KiB) Viewed 352 times
- ZigZag, 20% Step Over, 0.5 mm Sample Interval, and Optimize StepOver Transitions set to True
- Snip macro screenshot-403284.png (352.14 KiB) Viewed 352 times
