Afternoon sir.Joneb wrote: ↑Tue Apr 27, 2021 3:34 pm Good Afternoon I'm still having problems with this 3d surface for the top of this job, I thought this would be the easy part of machineing this cowl but I am trying to avoid cutting the boss in the middle, this is because that is how I have it fixed to the table with a bolt through the center. I have only face 1 and 8 selected but freecad insists on machining face 10, the boss, even though the boss is higher than the start depth. CowlTopSlice.PNG
CowlTop Slice.FCStd
In your particular case here, you should select (in this order): the outer curved disc ring, the inner lower, flat ring with the four mounting holes in it, and lastly the inner raised face. Then, change the `Avoid Last X Faces` property to a value to 1. This property is available in the Task Panel and the property list of the Data tab once the operation is created. This tells the op that you want to actually avoid the last 1 face(s) in the selection list as ordered. Since the last 1 face is as you call, `the boss`, then the op treats it as a no-cut zone.
Cheers,
Russell
