OpenCAMLib for Master (0.20)
Zivatar
Re: OpenCAMLib for Master (0.20)
Post by Zivatar »
Thank You Gene,
I did not think about the filename mismatch, and now I double checked. Everything seems to be ok, however in the attached file there is a mismatch at tools! After that I rebuilt everything (FreeCAD itself also), because the problem is still active. Every directories are clean now. I rebuilt the tools dictionaries and made doublecheck on tool files (which are now the defaults, and I set default tools in the settings of the command's panel...
Could you tell me what files are in Your FreeCAD/Mod/ocl/ folder? I think something is wrong there on my computer.
Thanks,
Zivatar
The error is as it earlier was:
11:07:56  Traceback (most recent call last):
  File "/home/zivatarw/MyDev/freecad-build/Mod/Path/PathScripts/PathUtils.py", line 60, in new_function
    res = function(*args, **kwargs)
  File "/home/zivatarw/MyDev/freecad-build/Mod/Path/PathScripts/PathOp.py", line 760, in execute
    result = self.opExecute(obj)  # pylint: disable=assignment-from-no-return
  File "/home/zivatarw/MyDev/freecad-build/Mod/Path/PathScripts/PathSurface.py", line 510, in opExecute
    self.cutter = oclTool.getOclTool()
  File "/home/zivatarw/MyDev/freecad-build/Mod/Path/PathScripts/PathSurfaceSupport.py", line 2649, in getOclTool
    oclToolMethod()
  File "/home/zivatarw/MyDev/freecad-build/Mod/Path/PathScripts/PathSurfaceSupport.py", line 2559, in _oclBallCutter
    self.oclTool = self.ocl.BallCutter(
<class 'AttributeError'>: module 'ocl' has no attribute 'BallCutter'
Zivatar
GeneFC
Post by GeneFC »
Sorry, I am away from my main CAD computer for a few days.
In any case, I do not have a "Mod/OCL" folder. I have only the precompiled OCL.pyd file that comes with the prepackaged versions of FreeCAD.
It is almost a certainty there is some problem with your installation. As Chris mentioned above it is recommended you use the ready-made appimage if you want to actually use FreeCAD and not experiment with custom modifications.
Gene
Zivatar
Post by Zivatar »
GeneFC wrote: Tue Oct 12, 2021 6:13 pm Sorry, I am away from my main CAD computer for a few days.
Gene
Dear Gene,
Thank You for Your attention and the suggestions!
Zivatar
