Post processor possible bug?
falviani
Postby falviani » Thu Apr 22, 2021 3:37 pm
Here is my setup:
OS: Windows 10 Version 2009
Version: 0.20.24756 (Git)
Hash: 2c072c70929bb359853bfa09a5b34977c8a0670b
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I have a simple 2-operation, 1-tool job where the generated code seems to include an old configuration:
I am using the grbl post processor. The generated call is this:
grbl(E:/3D CNC Projects/FreeCAD Projects/BitTray/FC_01-Collets-1_4em.gcode, --translate_drill --postamble "G0 X0 Y0 Z10;M5 G17 G90;M2;")
which is what I used to be using. A few days ago I decided to change the postamble slightly (copied directly from the dialog):
--translate_drill --postamble "G0 Z10;G0 X0 Y0;M5 G17 G90;M2;"
I have not only saved the preferences, I have relaunched Freecad after doing so, and the old postamble is still being used. Am I right in thinking this is a bug? If it is, is there a known workaround for it?
Thanks in advance,
Frank
onekk
Re: Post processor possible bug?
Postby onekk » Thu Apr 22, 2021 4:02 pm
It is not clear what you are asking.
If you are using the GUI there were some cells in the JOB I suppose PostProcessorArgs in the Output tab of the Job
I don't use Path with Gui (I have only done some scripting) but this place seem the most correct,.
However it is not a big hassle to change the lines directly in the generated Gcode, it is standard text file, so it is a mere copy and paste thing.
Regards
Carlo D.
Il mio Blog: https://onekk-maker.blogspot.com/
Introduzione a FreeCAD in Italiano: https://github.com/onekk/freecad-doc
Postby chrisb » Thu Apr 22, 2021 4:36 pm
Works flawless here. These are the last lines:
G2 X-1.116 Y4.354 Z-1.000 I4.354 J1.116 K0.000
G2 X3.178 Y3.178 Z-1.000 I1.116 J-4.354 K0.000
G0 Z9.000
G0 Z9.000
(Finish operation: Profile)
(Begin postamble)
OS: macOS 10.16
Version: 0.20.24720 (Git)
Hash: 8b0c58d1b45017ad42bf0fa8f827f1cf22a398e7
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
Locale: C/Default (C)
grblWithPost.FCStd
(11.75 KiB) Downloaded 12 times
spanner888
Postby spanner888 » Thu Apr 22, 2021 9:58 pm
falviani wrote: Thu Apr 22, 2021 3:37 pm A few days ago I decided to change the postamble slightly (copied directly from the dialog):
Did you only change this in your preferences? If so, then the change will only be applied when creating new path jobs.
If you wish to change this in an existing job then double click on the job in the tree and open the output tab and edit the arguments field.
falviani
Postby falviani » Sat Apr 24, 2021 8:07 pm
Yes, I changed this in my preferences, and the changes were not reflected in gcode generated after that. Chrisb says they worked for him, so I don't know what's up; this instance was compiled from the master.
-Frank
falviani
Postby falviani » Sat Apr 24, 2021 8:10 pm
Chris B -
Comparing your 'about' info with mine, I notice your Qt version is quite a bit newer than mine, yet I did a pull almost immediately preceding this test. What could be the cause? Shouldn't I have the same version?
Frank
spanner888
Postby spanner888 » Sat Apr 24, 2021 10:08 pm
falviani wrote: Sat Apr 24, 2021 8:07 pm Yes, I changed this in my preferences, and the changes were not reflected in gcode generated after that.
Sorry to be pedantic, but I am saying that this preference is ONLY applied when you create a NEW job, not when you generate (post process) gcode.
Postby chrisb » Sat Apr 24, 2021 10:49 pm
falviani wrote: Sat Apr 24, 2021 8:07 pm Yes, I changed this in my preferences, and the changes were not reflected in gcode generated after that. Chrisb says they worked for him, so I don't know what's up; this instance was compiled from the master.
I didn't change my preferences. I created a new job as spanner888 said. Did you check my file?
The different Qt versions come from the package mangers. I use the MacOS versions, and the libraries often differ.
