Memory usage with Surface toolpath
I used the surface toolpath for the first time yesterday and it looks like it isn't freeing the memory on each recompute. Memory usage goes up around 2000MB each time. Has anyone run into this or have any idea what to check. I built Freecad from source on Windows 10 and I am using the latest libpack. I'll attach the file if anyone wants to look at it. Thanks!
OS: Windows 10 Version 2004
Version: 0.20.Unknown
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Re: Memory usage with Surface toolpath
This happens on Ubuntu Linux as well. I find I have to shut FreeCAD down and restart to clear the memory.
It seems memory de-allocation is not being invoked correctly or is loosing track of the memory assigned location.
I have no solution though.
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
I see the following sizes:
463124 initial size after loading the file
2586840 after first recompute of the whole file
3448448 after second recompute
4415892 after third recompute
4241956 after closing the file
Sketch009 contains an error, so no complete recompute can be performed. My guess is, that the cleanup is not performed due to the error state, and not the Path operation.
Can you fix the model and retry?
Related note: when I open the file I get an error message in Report view:
We have seen something similar recently: https://forum.freecadweb.org/viewtopic.php?f=3&t=58194
OS: macOS 10.16
Version: 0.20.24720 (Git)
Hash: 8b0c58d1b45017ad42bf0fa8f827f1cf22a398e7
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
Locale: C/Default (C)
No profile linked
Linked shape object is empty
<Exception> Linked shape object is empty
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.1
My file didn't seem to have an error in Sketch009 so I don't know what happened for you. But the linked forum post was right I removed the hole features and the error when loading the file went away. It didn't make a difference about the memory usage though. I did see that I get the following error when recomputing the Surface toolpath:
07:54:38 <Path.Area> Area.cpp(1312): project failed
07:54:38 <Path.Area> Area.cpp(1614): skipped 1 sub shapes during projection
07:54:38 <Path.Area> Area.cpp(1672): Found 1 non coplanar shapes
07:54:38 PathSurfaceSupport.WARNING: getOffsetArea failed: 'bool' object has no attribute 'cut'; Using FindUnifiedRegions.
07:54:38 <Path.Area> Area.cpp(1432): hit bottom -0,0,1e-06
07:54:38 3D Surface operation time is 48.76989 sec.
This is then probably due to different OCC versions. I may have a look later.
I could "fix" the issue in Sketch009 by just removing all external geometry -leaving some degrees of freedom, but that's not relevant here. Besides some partially redundant constraints - which I always recommend to remove - there still is an error from Path workbench:
bmsaus4ax: your version is outdated, can you update to a recent one?
Bendall: I don't see a version number, did you compile yourself?
I would still like to see a confirmation on Bendall's issue with a current version and a try for a full recompute with OCC 7.5.1.
Tested on two versions as below.
The 0.19 version is reported as the latest by the in-program update.
Qt version: 5.12.9
OCC version: 7.4.0
Performed following sequence with accompanying Resource Monitor memory usage figures.
@ System idle, online, only resource monitor active 1.6GiB
@ FreeCAD open 1.7GiB
@ File open 1.8GiB
@ Recompute 4.7 GiB
@ Recompute again 5.5GiB
@ Close file without saving 5.5GiB
@ Reopen file 5.5GiB
@ Recompute again 8.3GiB
@ Run Simulation, successful no problems , completes ok 8.3GiB
@ Close file without saving 8.4Gib
@ Close FreeCAD 1.6GiB
Report view across whole process. all steps progressed unhindered regardless of warnings and faults.
3D Surface operation time is 1 min. 0.75522 sec.
3D Surface operation time is 47.40604 sec.
3D Surface operation time is 1 min. 1.29014 sec.
Version 0.20, latest as reported from in-program update.
Version: 0.20.24789 (Git) AppImage
Hash: 31b0f25b6df1d1707fdf74135093831eec4f0281
Qt version: 5.12.9
OCC version: 7.5.1
@ File open 1.9GiB
@ Recompute 5.0GiB
@ Recompute again 5.8GiB
@ Close file without saving 4.6GiB (did drop slightly)
@ Reopen file 4.6GiB
@ Recompute again 6.7GiB
@ Run Simulation, successful no problems , completes ok 6.7GiB
@ Close file without saving 5.4Gib ( partial drop again)
No profile linked
3D Surface operation time is 1 min. 0.7522 sec.
3D Surface operation time is 46.91526 sec.
No profile linked
3D Surface operation time is 1 min. 1.79336 sec.
I have rebuild something similar concerning 3DSurface. The situation is by far not as severe as it seemed to be. The error messages come probably from the vertical surfaces which cannot be projected.
417324 size of FreeCAD after loading
418980 after first recompute
422468 2nd recompute
423532 3rd recompute
425016 4th recompute
429424 after closing the file (size has grown!)
436680 reopen same file
427044 1st recompute
429112 2nd recompute
Bendall, can you check if it is from the Path side what you want?
- Brytech_new_cb.FCStd
- (23.71 KiB) Downloaded 39 times
chrisb, that file seems to work great and it does not increase memory usage with each recompute. It must be something wrong with the model I was using. And it calculates a whole lot faster then before. I do still get the following errors in the report view but it seems to work fine.
10:12:05 <Path.Area> Area.cpp(1312): project failed
10:12:05 <Path.Area> Area.cpp(1614): skipped 1 sub shapes during projection
10:12:05 <Path.Area> Area.cpp(1672): Found 1 non coplanar shapes
10:12:05 PathSurfaceSupport.WARNING: getOffsetArea failed: 'bool' object has no attribute 'cut'; Using FindUnifiedRegions.
I'm not sure what was causing it but I did get my project completed. Ill see what happens on my next project and go from there. Thank you so much for looking into that for me!
I think that these errors come from selecting vertical faces for the 3D surface tool. I didn't dig into a better selection, but I understand the message.
