Drilling op depth
dubstar-04
Drilling op depth
Postby dubstar-04 » Sun May 02, 2021 7:49 am
It appears that the drilling operation doesn't respect the opstartdepth. Rather the operation starts at the clearance height.
Looks like we are missing a move to the start depth:
G0 Z35.000000
G90
G1 X0.000000 Y0.000000 Z12.000000 <---- This line is missing
G99
G81 R33.000000 X0.000000 Y0.000000 Z0.000000
G80
G0 Z33.000000
G80
G0 Z33.000000
G0 Z35.000000
Thanks,
Dan
DrillTest.FCStd
(22.14 KiB) Downloaded 2 times
Re: Drilling op depth
Postby chrisb » Sun May 02, 2021 8:46 am
Confirmed. I also checked the documentation of my mill, and G81 does not contain the initial rapid move. Perhaps this is different for other machines.
dubstar-04
Postby dubstar-04 » Mon May 03, 2021 11:01 am
Thank you for confirming.
Much appreciated.
Dan
dubstar-04
Postby dubstar-04 » Tue May 04, 2021 6:53 am
Postby chrisb » Tue May 04, 2021 7:05 am
Thanks, even with color!
BTW: to reference a bug from the forum, it is sufficient to use the bug tag and write the bug number in between.
dubstar-04
Postby dubstar-04 » Tue May 04, 2021 11:59 am
What would the desired output be?
1. Rapid to the correct x/y position at clearance height
2. Rapid to the opstartdepth + safe height
3. Move to opstartdepth
for example, where:
Stock top = 30mm
safeHeight = 3mm
clearanceHeight = 5mm
opStartDepth = 12mm
opFinalDepth = 0mm
The output would be:
G0 Z35.000000
G90
G0 X0.000000 Y0.000000 <-- hole location
G0 Z15.000000 <-- opStartDepth + safeHeight
G0 Z12.000000 <-- opStartDepth
G99
G80
G0 Z33.000000
G80
G0 Z33.000000
G0 Z35.000000
Thanks,
Dan
dubstar-04
Postby dubstar-04 » Tue May 04, 2021 12:44 pm
Postby chrisb » Tue May 04, 2021 4:29 pm
:thumbsup:
