can't pocket the following shape
i'm a new at freecad and trying to learn and I want to try and pocket below but it is a complicated shape and every time I try to pocket it a new error pops out I have tried reading online but nothing helped me solve the problem I hope you can help me I have attached the file and I'm working on windows 10 i think it is an easy prob;lem but i'm still new to the program
- meng364.FCStd
- (11.79 KiB) Downloaded 26 times
Re: can't pocket the following shape
Hi and welcome to the forum!
Your sketch is not properly closed. Sketcher's validation tool helps you to identify the culprits.
I very strongly recommend to avoid the block constraint for this sketch. Having a fully constrained sketch is no end in itself, and with the block constraints you don't see anymore what the geometry is all about.
There is something interesting though with Sketch001 in your model:
The sketch is fully constraint without any conflicts. If I remove Constraints 2, 11, 12 the solver reports redundant constraints. So I guess this is another example of issue #4673 or issue #4636.
Can someone else please verify?
OS: macOS 10.16
Version: 0.20.24825 (Git)
Hash: ccc4151b3020969450325466e385850783795325
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
Locale: C/Default (C)
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.1
