Version: 0.19.Unknown
Build type: Unknown
Python version: 3.9.4
Qt version: 5.15.2
OCC version: 7.5.0
I've found a bug in the split output function in 0.19.2 when ordering by Operation. To reproduce, make a part with at least two operations, say a pocket and a profile operation. Use the same tool for each operation (very important as if you use different tools you won't see the bug). A file is generated for each operation BUT only the first file contains an M3 command. Attempting to run any of the other files will result in the cutter entering the stock with the spindle idle!
The fix, for the 0.19.2 code base, is in PathPost.py line 383 change
if tc.ToolNumber != currTool:
if tc.ToolNumber != currTool or split is True:
Looking at GitHub it looks like the bug has been fixed for Operations but is still there for Fixtures so that needs fixing.
Meanwhile, as I need Split by Operation for an upcoming project I've resorted to applying the edit locally.
