Can you add the non working file as well?
Milling an area with open edges
Re: Milling an area with open edges
The file I attached includes the working and failed bodies.
Body: Was done using sketch to provide the fillets and this works ok
Body001: Was done using Part Design to provide the fillets and this fails with MillFace.
Thanks,
MPC.
Thanks,
MPC.
Sorry, I missed the second body.
At least the front lines of the pockets are different: Body has 20 vertices and 30 edges, Body has 22 vertices and 32 edges.
When I open the file, the MillFace in Job is marked to be recomputed, and if I do so, it shows an error:
File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathUtils.py", line 60, in new_function
res = function(*args, **kwargs)
File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathOp.py", line 552, in execute
result = self.opExecute(obj) # pylint: disable=assignment-from-no-return
File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathAreaOp.py", line 316, in opExecute
aOS = self.areaOpShapes(obj) # pylint: disable=assignment-from-no-return
File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathMillFace.py", line 196, in areaOpShapes
baseShape = oneBase[0].Shape
<class 'UnboundLocalError'>: local variable 'oneBase' referenced before assignment
I may be out of date, but it seems that face milling may not be the correct operation. I tried the sample file "Test_using_sketch_fillet.FCStd", and both bodies worked just fine when I used "Pocket" operations with extensions checked.
Gene
Gene
Pocket does not extend enough beyond the edge to correctly finish the fillet.
In the file attached Body001 uses a pocket to clear the area with edge extension but the operation does not complete the fillet correctly.
You are left with a small bit of material.
Millface does extend correctly but only if the fillets are done in sketch. If they are done in Part Design the mill face fails with errors.
- Test_using_sketch_fillet2.FCStd
- (89.29 KiB) Downloaded 30 times
Afternoon sir.
In short, here is my recommended, verified solution using the last file you posted.
1. Download the Development AppImage of FreeCAD with instructions at AppImage. This contains recent upgrades to the Extensions feature.
2. Use either the Extensions feature with either the regular Pocket or the Adaptive operations.
3. Set the Extensions `Default Length` expression to only `OpToolDiameter` (This will be calculated to 5.0 mm for default tool.)
4. Select the `Extend_Face` extension option. Clicking on this option will add a bright pink visual extension preview to the viewport, as you are likely aware.
5. Press `Apply` button to inspect the result.
Thanks for the feedback and involvement in the forum.
Russell
OS: Windows 10 Version 2009
Version: 0.20.25170 (Git)
Branch: Master_c401e3
Hash: c401e3efe3756b8cab0c95bc3b8afa2e23e464a7
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- Test_using_sketch_fillet2 - Copy.FCStd
- (392.81 KiB) Downloaded 26 times
- Snip macro screenshot-54636b.png (209.52 KiB) Viewed 1356 times
- Snip macro screenshot-1dffd2.png (198.79 KiB) Viewed 1356 times
- Snip macro screenshot-7d71ad.png (198.45 KiB) Viewed 1356 times
- Snip macro screenshot-80c0a1.png (212.86 KiB) Viewed 1356 times
This is super useful thank you.
I have just built FC (git)
I did an adaptive clearance, with a 4mm endmill, and set the extension to 4mm.
Update:
got it work by setting the extension to 3,5mm, however the feature should also respect the spacing to the wall in the extension... ----
This green straight line doesn't seem good: Update:
I'm using a smaller endmill now and that line is gone, so seems like it shows up with bigger diameters and some special pathways.
I'm getting this error in the logfile:
Update:
Good morning, MRx.
Yes, my tests also revealed that adjusting the length of the extension, like your 4.0mm to 3.5mm here, helps Adaptive correct the irregularities/failures in some of the situations.
Re: First image
I am curious about the actual extension face produced in that image. Are you able to share the model file you used for that image? It looks like a there is a double fillet, one on top and one directly below, the extension face. This might be negatively affecting the creation of the extension face. I would like to take a look if possible.
Thanks for reporting these issues.
Russell
This has already been addressed in PR #4902, [Path] Downgrade Extensions error message priority. It is a leftover feedback message from coding the recent Extensions upgrades.
Yes, the availability of more complex shapes via the extensions upgrade is exposing some weaknesses within the Adaptive algorithm. There have been Adaptive bugs reported here in the forum prior to this Extensions upgrade, many related to complex curves/shapes. The use of the newly added Extensions feature in Adaptive is only going to increase the frequency of bug manifestations due to the increase in complex shapes passed thereto.MRx wrote: ↑Sun Jul 11, 2021 9:21 am ... I did an adaptive clearance, with a 4mm endmill, and set the extension to 4mm. ...
Update:
... This green straight line doesn't seem good: ...
Re: First image
Russell
I think I figured out what the problem is, I selected wire instead of extend face
Wire: Face:
I just wanted to reproduce the first issue (wire vs face, but then I was able to reproduce the other issue which I mentioned):
the freecad file is attached. Please see my other forum post a serious issue got introduced with FC 0.20
https://forum.freecadweb.org/viewtopic.php?f=15&t=60037
Wire: Face:
- mpbug1.FCStd
- (61.94 KiB) Downloaded 25 times
