Milling an area with open edges
Sorry I posted this on the general freecad help but its more a PATH related.
Any ideas how to mill out an open edge area?
I have tried several different attempts but I have completely failed. Any suggestions?
Kind Regards,
MPC
Kind Regards,
MPC
Re: Milling an area with open edges
I removed the duplicate from the help forum.
I'm not a professional machinist so I might be wrong but I think you're supposed to mill the face before performing the pocketing.
Use a pocket and check the appropriate edge in the Extensions tab.
As ChrisB suggested, and MLampert encourages, use the Extensions feature of the regular Pocket operation to extend edges, expanding access to such regions. See the last image.
EDIT: A second option is to select both the upper open edge face and the inner lower and clear them together at the upper face depth, then do a second clearing op with only the inner lower selected. See second and first image.
BR,
Russell
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
- Upper open face and lower inner face cleared together will grant access to that open edge (ledge, shelf)
- Snip macro screenshot-06488a.png (216.52 KiB) Viewed 2889 times
- Alternative strategy, selecting upper and lower faces and clearing at upper height, then create clearing op for lower only.
- Snip macro screenshot-dda7d3.png (200.53 KiB) Viewed 2891 times
- plate_replica_1.FCStd
- Pseudo replica source file
- (231.76 KiB) Downloaded 48 times
- Extension feature usage, with Default Length increased slightly
- Snip macro screenshot-80f7ec.png (217.83 KiB) Viewed 2909 times
Thanks for the suggestions.
Unfortunately it still fails.
Below is the pocket with the wire extension checked and Extend corner checked. You can see the cutter is driven into the part.
Below is the Extend Corners unchecked but all edges checked
Below is the Extended Corners unchecked but only partial edges selected.
This is from a different body where I used Mill Face with Boundary Shape set to 'Face Region' and this successfully extended beyond the open edges. This does not work with the fillet part though.
I get this error message when I try Mill Face with Boundary Shape set to 'Face Region' on the Fillets.
Could it be that the fillets were done in Part Design and not done as part of the sketch?
Any more thoughts?
Kind Regards,
MPC
Any more thoughts?
Kind Regards,
MPC
I don't think that Path workbench cares about how an object was built, but running CheckGeometry with BOPCheck enabled is probably a good idea.
Thanks chrisb,
I tried your suggestion but I got no errors.
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Qt version: 5.12.9
OCC version: 7.4.0
Preliminary remark: The PartDesign features have a Refine property which make the separate object obsolete.
Concerning the rounded corner: In the attached example I used a profile of the to face and changed the depth appropriately. Then I added a boundary dressup. It's not exactly what you want, because it creates additional paths, but it does at least do the job in an automated way.
- plate_replica_cb.FCStd
- (159.05 KiB) Downloaded 49 times
Thanks chrisb,
That's a very useful suggestion.
I did a bit more experimenting and found something very interesting.
I built a cube with a pocket and fillet edges.
1. I did the fillet using sketch --- Mill face worked and extended correctly
2. I did the fillet using part design. --- Mill Face failed with error --> 19Standard_OutOfRange NCollection_Sequence::Value19Standard_OutOfRange NCollection_Sequence::ValueSomething unexpected happened. Check project and tool config.
Below is the working mill face
Is this worth raising as a bug?
Kind Regards,
MPC
Kind Regards,
MPC
- Test_using_sketch_fillet.FCStd
- (78.88 KiB) Downloaded 55 times
