Error while generating a circular path?
I've generated the code to mill an U-Washer from Delrin material.
My first operation is a rough cleaning of the circular pocket, before finishing the walls. For this task I've generated an edge-milling operation with some offset:
(End-mill dia = 2 mm)
Only today I discovered that... there is a G1 instruction (linear movement) in the middle of the circular path.
Is this normal?
I'm missing something?
I attach the FCstd file.
OS: Ubuntu 16.04.7 LTS (XFCE/xfce)
Version: 0.20.25065 (Git) AppImage
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.9.4
Qt version: 5.12.9
OCC version: 7.5.2
Is this normal?
Qt version: 5.12.9
OCC version: 7.5.2
- U-Scheiben-1.0.FCStd
- (41.95 KiB) Downloaded 29 times
- sliptonic
Re: Error while generating a circular path?
Looks like curve accuracy thing.
Increase your accuracy here and recompute.
1. raised tolerance and accuracy to 0,001 mm
2. "apply" button pressed
3. "ok" button pressed
4. Freecad restarted
5. file loaded
6. "post process" button pressed and file saved
The resulting gcode is the same: still 185 lines of code with no changes.
5. file loaded
- Selection_7418.jpg (52.43 KiB) Viewed 1481 times
Maybe I have to updated the Path Workbench?
Unfortunately it is not listed in the Addon-manager list...
P.S.
I tried also to set 0,0001 mm as value for Tolerance and accuracy both. Again no changes in the output code.
P.S.
Path workbench belongs to the core system. It updates when you update FreeCAD.
I was thinking about that...
Any idea about the problem?
I don't see these G1 commands, this is the pocket1/2 part:
I have set both tolerance values to 1µm.
(begin operation: pocket-1/2)
(machine units: mm/min)
(pocket-1/2)
(Compensated Tool Path. Diameter: 2.0)
G0 Z5.000
G0 X7.482 Y7.482
G0 Z3.000
G1 X7.482 Y7.482 Z-0.800 F120.000
G3 X5.585 Y8.054 Z-0.800 I-1.482 J-1.482 F799.998
G3 X6.415 Y3.946 Z-0.800 I0.415 J-2.054 F799.998
G3 X7.482 Y7.482 Z-0.800 I-0.415 J2.054 F799.998
G1 X7.482 Y7.482 Z-1.600 F120.000
G3 X5.585 Y8.054 Z-1.600 I-1.482 J-1.482 F799.998
G3 X6.415 Y3.946 Z-1.600 I0.415 J-2.054 F799.998
G3 X7.482 Y7.482 Z-1.600 I-0.415 J2.054 F799.998
G1 X7.482 Y7.482 Z-2.400 F120.000
G3 X5.585 Y8.054 Z-2.400 I-1.482 J-1.482 F799.998
G3 X6.415 Y3.946 Z-2.400 I0.415 J-2.054 F799.998
G3 X7.482 Y7.482 Z-2.400 I-0.415 J2.054 F799.998
G0 Z5.000
G0 Z5.000
(finish operation: pocket-1/2)
Nevertheless, I still see that G1 instructions in my output file:
(Profile001)
G0 Z5.000
G0 X7.482 Y7.482
G0 Z3.000
G3 X5.574 Y8.052 Z-0.800 I-1.482 J-1.482 F799.998
G3 X6.415 Y3.946 Z-0.800 I0.427 J-2.052 F799.998
G1 X6.679 Y4.017 Z-0.800 F799.998
G3 X7.482 Y7.482 Z-0.800 I-0.679 J1.982 F799.998
G3 X5.574 Y8.052 Z-1.600 I-1.482 J-1.482 F799.998
G3 X6.415 Y3.946 Z-1.600 I0.427 J-2.052 F799.998
G1 X6.679 Y4.017 Z-1.600 F799.998
G3 X7.482 Y7.482 Z-1.600 I-0.679 J1.982 F799.998
G3 X5.574 Y8.052 Z-2.400 I-1.482 J-1.482 F799.998
G3 X6.415 Y3.946 Z-2.400 I0.427 J-2.052 F799.998
G1 X6.679 Y4.017 Z-2.400 F799.998
G3 X7.482 Y7.482 Z-2.400 I-0.679 J1.982 F799.998
G0 Z5.000
G0 Z5.000
- U-Scheiben-1.0-again.txt
- (6.53 KiB) Downloaded 19 times
I tried to set the tolerance/accuracy to 0.0001 mm, but I got the same output file.
In order to set 1 micrometer I should set the Preferences to allow 6 decimal digit. This could be quite annoying when entering values through the general Freecad interface...
UPDATE
I tried to set the accuracy/tolerance to 1 micrometer. No way, the G1 instruction is still there....
UPDATE
I have to confirm the OP report with the tighter tolerance values:
(Profile001)
G0 Z5.000
G0 X7.482 Y7.482
G0 Z3.000
G0 Z5.000
G0 Z5.000
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.20.25148 (Git)
Hash: 835e3266525580ed3c5fa47e27b33431840d62ee
Python version: 3.6.9
Qt version: 5.9.5
