G-Code generation bug
Hello everybody!
I'm completely beginner here.
First of all, I want to say a huge thank to the entire community, especially, of course, the developers for the program. I just found it for myself, but I already understand that it is great for my hobby tasks.
I looked for a similar error on the forum, but didn't really find anything, so I opened here a new topic.
I use the following configuration:
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.19.24276 (Git)
Build type: Unknown
Branch: releases/FreeCAD-0-19
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.0
After G-code generation in the G-code there are some wrong lines, correspond to the same places in the trajectory, but located in different layers strictly one above the other.
In my model the problematic places are located in the following area: And more detailed: The error lines are exactly the same.
I attached the G-code file. The wrong lines are 929, 1125, 1214, 1413, 1609, 1694. All lines are identical. As you can see above, the wrong commands are not visible on the render, but the path-simulator freezes when it gets to this point. The print-screen of froozen FreeCAD with path-simulator is shown here: FCStd-file is also attached here: I just deleted these wrong lines from G-code and my part was machined completely properly.
Thank you very much!
Build type: Unknown
Qt version: 5.12.8
OCC version: 7.5.0
Re: G-Code generation bug
Hi and welcome to the forum!
Can you reduce this to a single Path operation?
And by the way, why do you use 3D pocket instead of the normal pocket?
Those lines are not errors. They are very short arcs with essentially infinite radius.Therefore they act as short straight lines.
The Pocket 3D operation is quite complex, and it tries to fit the shapes it finds using either arcs or straight lines. Tolerances allow either to be correct.
To a human it sometimes seems silly to have a short straight line in the middle of arcs or a short arc in the middle of straight lines, but they do not usually cause any noticable effects.
I had no problem simulating the complete shape, so I do not know what you saw that did not look right.
I did notice that the FCStd file is rather strange. There is a second body that contains some elements of a Job, but not a complete Job. Did you create something and then try to delete it or drag it in the tree?
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.25157 (Git)
Branch: Master
Hash: 257cdd8f423f1530b8df6f53e242de629fee4e85
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Gene
As Gene has pointed out the short segment is an arc with a massive centre point relative X dimension.
I am using a relatively slow processor PC and I do get the freeze . Inspecting the system Resource Monitor for the processor I can see that the CPU is working on resolving the path, so a fast machine may not show the pause.
When run individually Pocket_3D003 is the only one that causes any problem because of this radius being present.
But there may still be something like a bug in the 3D Pocket Operation. If I toggle any of the 3D Pocket Ops "Toggle Active State of the Operation" from Inactive to Active this creates a fault per the trace back report
File "/tmp/.mount_FreeCAVviZjB/usr/Mod/Path/PathScripts/PathUtils.py", line 60, in new_function
res = function(*args, **kwargs)
File "/tmp/.mount_FreeCAVviZjB/usr/Mod/Path/PathScripts/PathOp.py", line 552, in execute
result = self.opExecute(obj) # pylint: disable=assignment-from-no-return
File "/tmp/.mount_FreeCAVviZjB/usr/Mod/Path/PathScripts/PathAreaOp.py", line 347, in opExecute
for shape, isHole, sub in shapes:
<class 'ValueError'>: too many values to unpack (expected 3)
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.25157 (Git) AppImage
Python version: 3.9.5
Qt version: 5.12.9
OCC version: 7.5.2
Thanks for the feedback. This error is due to return values that did not get adjusted with the recent rotational purge.bmsaus4ax wrote: ↑Thu Jul 01, 2021 12:34 am ...
But there may still be something like a bug in the 3D Pocket Operation. If I toggle any of the 3D Pocket Ops "Toggle Active State of the Operation" from Inactive to Active this creates a fault per the trace back reportIf run first before making inactive the operations run ok. Toggling it renders it inoperable from then on.Code: Select all
... File "/tmp/.mount_FreeCAVviZjB/usr/Mod/Path/PathScripts/PathAreaOp.py", line 347, in opExecute for shape, isHole, sub in shapes: <class 'ValueError'>: too many values to unpack (expected 3)
PR #4901 [Path] Fix 3D Pocket tuple lengths in return values is active with the fix.
Russell
Hello chrisb.
Thank you very much for the answer. I'm positively surprised, how many answers I have received!
I tried to make it with single operation, but it calculates than only to the depth with a nearest horizontal surface (locates at depth -2,2mm from stock top surface).
So it looks: The model is attached: Tu cut further I make new operation with the start depth below -2,2 mm and with the chosen geometry below this depth only. So it calculates till next horizontal surfaces, and so on. Thus, in this model, I did 3 operations of 3D-Pocket.
With normal pocket I also tried, but received the following complexity:
and
As you see, there are not machined areas (are marked on the pictures above), and I have no idea how to proceed with normal pocket operation.
The model is also attached to the post: With best regards,
Alexey
Hello Gene!GeneFC wrote: ↑Thu Jul 01, 2021 12:05 amThose lines are not errors. They are very short arcs with essentially infinite radius.Therefore they act as short straight lines.
Branch: Master
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Gene
Thank you for your answer and comments.
Yes, I noticed, that in principle this arc is as a little straight line. In principle, deleting of these lines is giving exactly a straight line instead of arc.
May be it calculates on your computer correctly due to another system and configuration, but on my computer it stacks exactly on this moment. And as bmsaus4ax wrote, at his computer as well.
About the infinitely large radius, maybe, of course, I have an old post processor. I am using a quite old LinuxCNC with my CNC-mashine, but before that there were no problems with it. And here it shows a huge circle, i.e. he drows not an arc, but an almost full circle, with a very small gap. So it also draws an arc, but a larger segment of the circle, not a smaller one.
Thanks for the remark with duplicate operations. I don't know how they were added, I guess I accidentally did something wrong. I removed them, making the project tree neat. But this will not affect the creation of the trajectory.
I understand why you used more than one operation. I wanted you to reduce it just for demonstrating the issue, but I think that Gene has already explained where it comes from.
And I have two more questions. I don’t know whether to create a new topic for each question, or ask in an existing one, so I ask here first.
Question 1
I cannot figure out what I am doing wrong in this file.
For some reason the trajectory (and cut material, if exists) is displayed with a shift relative to the part. But when I select either the stock or an operation in the project tree, the display becomes correct:
Project tree components are inactive: Either the stock or an operation is active in the project tree: The model file is the following: Question 2
In path simulation it shows bigger hole, as shall be. Seems, like it uses for cut material calculation not a cut edge diameter of a bit, but its shank diameter. The same thing I have in both models, from this and previous posts.
There is also similar topic here: https://forum.freecadweb.org/viewtopic.php?f=15&t=59645
But in my case path self is correct, I already cut both parts, and they are absolutely OK, in my case it is only a visualization issue in path simulation.
Question 1
On Job creation a clone is created, in your case "Model-Body001". You have moved this clone, and path generation is taken out on the new position.
This is probably a bug, probably in the simulator.In path simulation it shows bigger hole, as shall be. Seems, like it uses for cut material calculation not a cut edge diameter of a bit, but its shank diameter.
