Update with FC 0.20 (Git):
generating a path from selected outlines does not work anymore, it gives many errors:
I figured this out since my object relies on this feature, and that worked properly with FC 0.19 (but 0.19 does not support extensions with adaptive), now with FC 0.20 if I modify any settings in the Path setup sheet it will try to recreate all the paths which were created using edges. All the edge based paths will be erased from my original model
22:50:59 PathFeatureExtensionsGui.ERROR: _resetCachedExtensions()
22:50:59 Traceback (most recent call last):
File "/Users/markus/devel/freecad/build/Mod/Path/PathScripts/PathUtils.py", line 60, in new_function
res = function(*args, **kwargs)
File "/Users/markus/devel/freecad/build/Mod/Path/PathScripts/PathOp.py", line 552, in execute
result = self.opExecute(obj) # pylint: disable=assignment-from-no-return
File "/Users/markus/devel/freecad/build/Mod/Path/PathScripts/PathAdaptive.py", line 694, in opExecute
self.pathArray = _get_working_edges(self, obj)
File "/Users/markus/devel/freecad/build/Mod/Path/PathScripts/PathAdaptive.py", line 587, in _get_working_edges
wire_B = face.Wires[0]
<class 'IndexError'>: list index out of range
22:52:38 PathGeom.INFO: Zero working area to process. Check your selection and settings.
22:52:38 PathAdaptive.INFO: *** Adaptive toolpath processing started...
22:52:38 PathAdaptive.ERROR: No wire data returned.
OS: macOS 10.15
Version: 0.20.25220 (Git)
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.9.0
Qt version: 5.15.2
OCC version: 7.5.0
Locale: English/Germany (en_DE)
I'm working on one part which has multiple faces on the same Z level including some pockets, it would be nice to be able to clear at once with the adaptive feature.
The way I usually handle those things is to copy the object, remove the pocket and run the adaptive clearing over it to create the path, however it would be much better to be able to do this without this additional step.
Face Operation / ZigZag is not an option for Aluminium since it doesn't respect climbing / conventional and it adds different pressure on the tool.
Face Region, Spiral:
is following expected?
Climbing vs Conventional:
https://www.youtube.com/watch?v=bRjnk9GOo_w
On the actual model (not the one which I have uploaded) I get following message with the face operation (I still need to isolate how I get there), and the face operation is also very slow (while adaptive is much better).
21:31:10 19Standard_NullObject BRep_Tool:: TopoDS_Vertex hasn't gp_Pnt19Standard_NullObject BRep_Tool:: TopoDS_Vertex hasn't gp_PntSomething unexpected happened. Check project and tool config.
Anyway I need the Adaptive feature going over everything not the Face Operation.
Adaptive clearing on multiple faces (fixed)
- Multisurfaces.FCStd
- (66.14 KiB) Downloaded 19 times
Re: Adaptive clearing on multiple faces
Problem solved by selecting the outline (even on different Z heights!)
Re: Adaptive clearing on multiple faces (re-opened / freecad git bug)
ok this is now a bug in FreeCAD 0.20 (latest git version)
Did you totally rebuild the job in version 0.20 or did you try to continue work on a job created in 0.19?
Gene
Gene
Yes, I cannot even select the outline of a square and apply adaptive clearing with the latest git version.
Afternoon sir.
Got it. PR #4917, [Path] Adaptive: Correct the processing of selected edges, is active now.
Thanks for reporting this!
Have a great day.
Russell
Have a great day.
Russell
That fixes it thanks!
