I was just playing with the "Linear2D" array command to duplicate some circular pockets on a plane.
I noticed that if I try to simulate the path then only the milling ops on the first pocket are executed, the other pockets are ignored.
I missing something?
(I attach my file.)
OS: Ubuntu 16.04.7 LTS (XFCE/xfce)
Version: 0.20.25065 (Git) AppImage
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.9.4
Qt version: 5.12.9
OCC version: 7.5.2
Path simulator bug?
Path simulator bug?
- Selection_7431.jpg (29.71 KiB) Viewed 1158 times
Re: Path simulator bug?
Afternoon from the sunny state of Oklahoma in the United States of America. I am taking a look at your file and the issue you are reporting. First test confirms your reported issue. I am now looking into the code for the cause.Giulio Buccini wrote: ↑Sat Jul 10, 2021 9:15 pm ... I noticed that if I try to simulate the path then only the milling ops on the first pocket are executed, the other pockets are ignored.
I missing something? ...
Russell
Me again.
The problem appears to be that the `Array` object lacks the `Active` property that other operations possess. I will see if I can identify a proper solution for this issue. Feel free to create a bug tracker ticket for this issue.
I currently have an open PR that refactors the `PathArray` module. If I identify a solution to this issue, I may append it to that PR.
Thanks for reporting the matter. Have a great afternoon.
Russell
Russell
Hi Russel, 3:30 AM here in Germany.
Anyway the generated g-code seems ok to me. So it seems a problem of the simulator only. Can you confirm?
P.S.
Following the link you posted I read: "IMPORTANT: POST ONLY 0.19 BUG REPORTS"
I'm using version 0.20 ...
P.S.
Good early German morning!Giulio Buccini wrote: ↑Sun Jul 11, 2021 1:44 am ... So it seems a problem of the simulator only. Can you confirm? ...
I can confirm the issue is isolated to the simulator.
I have added a simple fix, adding the `Active` property to the Array object, to the existing PR #4818, [Path] Refactor path array algorithm into independent PathArray class. I tested the fix and it does allow the simulator to include the Array object in the simulation. I also added the Path Array operation to the recognized list for the `Active` toggle in the Path WB toolbar since it will now have the dependent `Active` property for the toggle process.
The bug does exist in 0.19 also. You are simply a very astute individual that uses the latest and greatest version.Giulio Buccini wrote: ↑Sun Jul 11, 2021 1:44 am ...
P.S.
Have a great day. Thanks for making FreeCAD better.
Russell
- Simulator including the Array object
- Snip macro screenshot-a07149.png (246.93 KiB) Viewed 1085 times
- Newly added `Active` property for `Array` objects
- Snip macro screenshot-deea19.png (268.64 KiB) Viewed 1085 times
