Red = cut needed
green = part to be made
"blue" = cnc work area
Short of making a small pocket to simulate profile edge, is there a way to plot like this?
part larger than cutting area, how to plot?
- cutout.png (194.9 KiB) Viewed 1140 times
Re: part larger than cutting area, how to plot?
so the way I do it now, is to make a sketch around part and plot PathSHape OP.
is there a way to set number of z step downs on PathShape?
- shape.png (228.77 KiB) Viewed 1125 times
I'm not sure what you mean by "plot". Is it like milling without tool radius compensation? Then you can use a Profile operation and uncheck "Use Compensation".
Have a look at this thread https://forum.freecadweb.org/viewtopic. ... 20#p503984
This may be another option to what I gather you are trying to achieve. You could be able to process the job as a number of smaller tile jobs.
