SPINDLE_WAIT
phil from seattle
SPINDLE_WAIT
Post by phil from seattle »
I am a bit of a FreeCAD newbie but pretty experienced in other CAD and CAM systems.
I see this in the grbl_post.py script:
      if SPINDLE_WAIT > 0:
        if command in ('M3', 'M03', 'M4', 'M04'):
          out += linenumber() + format_outstring(outstring) + "\n"
          out += linenumber() + format_outstring(['G4', 'P%s' % SPINDLE_WAIT]) + "\n"
          outstring = []
Where do I set SPINDLE_WAIT in FreeCAD? I've looked through Path/* and Edit/Preferences/Path/*
spanner888
Re: SPINDLE_WAIT
Post by spanner888 »
phil from seattle wrote: Fri Jul 30, 2021 6:02 pm Where do I set SPINDLE_WAIT in FreeCAD?
Looks like this is set when creating or editing the Job, in the Output Tab, Arguments field. Hover to get help text, or since you are already looking in grbl_post.py then see around line 100:
parser.add_argument('--wait-for-spindle',   type=int, default=0, help='Wait for spindle to reach desired speed after M3 / M4, default=0')
Re: SPINDLE_WAIT
Post by Kunda1 »
@spanner888, offtopic github tip (should also work for gitlab).
phil from seattle
Re: SPINDLE_WAIT
Ah! thank you. I guess I am just too impatient - hover delay seems pretty long.
spanner888
Re: SPINDLE_WAIT
Kunda1 wrote: Fri Jul 30, 2021 11:55 pm @spanner888, offtopic github tip (should also work for gitlab).
Nice tip thanks.
