Creating a 2D path job for ShapeStrings fails
mclane
Post by mclane »
Hello,
I tried to repoduce the work shown in this YouTube video:
https://www.youtube.com/watch?v=mC21T943auk
However, when I want to create a path job, I get the following error:
15:20:50  Traceback (most recent call last):
  File "/usr/lib/freecad/Mod/Path/PathScripts/PathStock.py", line 153, in onChanged
    self.execute(obj)
  File "/usr/lib/freecad/Mod/Path/PathScripts/PathStock.py", line 147, in execute
    shape = Part.makeBox(self.length, self.width, self.height, self.origin)
<class 'ValueError'>: height of box too small
15:20:50  PathJobGui.ERROR: height of box too small
15:20:50    File "/usr/lib/freecad/Mod/Path/PathScripts/PathJobGui.py", line 1561, in Create
    obj = PathJob.Create("Job", base, template)
15:20:50    File "/usr/lib/freecad/Mod/Path/PathScripts/PathJob.py", line 718, in Create
    obj.Proxy = ObjectJob(obj, models, templateFile)
15:20:50    File "/usr/lib/freecad/Mod/Path/PathScripts/PathJob.py", line 244, in __init__
    obj.Stock = PathStock.CreateFromTemplate(obj, json.loads(stockTemplate))
15:20:50    File "/usr/lib/freecad/Mod/Path/PathScripts/PathStock.py", line 390, in CreateFromTemplate
    return CreateFromBase(job, neg, pos, placement)
15:20:50    File "/usr/lib/freecad/Mod/Path/PathScripts/PathStock.py", line 267, in CreateFromBase
    obj.Proxy.execute(obj)
15:20:50    File "/usr/lib/freecad/Mod/Path/PathScripts/PathStock.py", line 147, in execute
15:20:50  ValueError: height of box too small
15:20:50
The project file is simple: it just contains a ShapeString object (as in the YT video), but I have attached it. What is wrong here?
Thanks for any help.
My FreeCAD installation:
OS: Manjaro Linux (XFCE/xfce)
Version: 0.20.25697 (Git)
Hash: da918350c9efbd7751bd7e48a71cd4bded571500
Python version: 3.9.6
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
test.FCStd
(9.71 KiB) Downloaded 53 times
GeneFC
Re: Creating a 2D path job for ShapeStrings fails
Post by GeneFC »
I am not sure what went wrong, and I did not watch the video, but I had no problem with creating a Job and a path.
I just selected the ShapeString, selected the Job icon, accepted all defaults, and then selected the Engrave operation. I did not try to set any parameters.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.25645 (Git)
Hash: 37d9757399b4c2ec30318eb88d7cd7c508246345
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Gene
mclane
Post by mclane »
Thanks for trying to reproduce it. The error occurs when I want to create the path job.
You are using a slightly older Python version (3.8.6+) compared to mine (3.9.6), maybe the problem comes from there?
bmsaus4ax
Post by bmsaus4ax »
mclane wrote: Thu Sep 16, 2021 1:27 pm Hello,
I also use a Linux version and get the error you do.
I find if you create the path job with both your job model and the ShapeString selected the tool path will be produced.
In preparation, position the ShapeString on the surface of the job. (Z offset either the job or ShapeString)
The Depths, Final Depth setting will need to be set to the desired value.
Attached modification of your file to illustrate for V-Carve and Engrave.
If at some stage you get the following error, you need to save your file and close out of FreeCAD completely and restart. The saved file will then work again.
Free Select
Running the Python command 'Path_Simulator' failed:
  File "/tmp/.mount_FreeCAzGNuYe/usr/Mod/Path/PathScripts/PathSimulatorGui.py", line 588, in Activated
    pathSimulation.Activate()
  File "/tmp/.mount_FreeCAzGNuYe/usr/Mod/Path/PathScripts/PathSimulatorGui.py", line 103, in Activate
    self.onJobChange()
  File "/tmp/.mount_FreeCAzGNuYe/usr/Mod/Path/PathScripts/PathSimulatorGui.py", line 459, in onJobChange
    for op in j.Operations.OutList:
Cannot access attribute 'Operations' of deleted object
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.25645 (Git) AppImage
Python version: 3.9.7
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.2
test_mod.FCStd
(65.86 KiB) Downloaded 49 times
I can confirm the issue, I see the message in Report view. It vanishes if I extend the Z of the stock by some positive value.
DaveHarm
Post by DaveHarm »
I am new user of FreeCAD version 0.19 on Linux Mint and just getting started with the Path toolbox and am seeing the "length of box too small" error also.
It looks like maybe a round-off error? The amount the box is too small is tiny but appears visible at both the tip of my model and the bottom.
I'm not a coder but are self.length, self.width and self.height returning values that round down for some reason? Is there a fix somewhere?
sliptonic
Post by sliptonic »
chrisb wrote: Fri Sep 17, 2021 7:11 am I can confirm the issue, I see the message in Report view. It vanishes if I extend the Z of the stock by some positive value.
Will you test this again please? I'm unable to reproduce the issue but I'm still on Python 3.8.10
sliptonic wrote: Mon Mar 07, 2022 9:16 pm Will you test this again please? I'm unable to reproduce the issue but I'm still on Python 3.8.10
Tested and works now without issue.
OS: macOS 10.16
Version: 0.20.27770 (Git)
Python 3.9.10, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: C/Default (C)
agren
Post by agren »
Unless I've misunderstood the OP I believe I'm still seeing this on:
OS: Ubuntu 20.04.4 LTS (MATE/mate)
Version: 0.20.27968 (Git)
Build type: Debug
Hash: bda12907dee4fe3f0e7dec8f7e09e098fc5036e4
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, OCC 7.5.2
Steps to reproduce:
Set Edit->Preferences->Path->Job Preferences->Setup
  1. Set Edit->Preferences->Path->Job Preferences->Setup
    • Stock: Enabled
    • Extend Models Bounding Box
    • Ext.X: 1 mm, 1 mm
    • Ext.Y: 1 mm, 1 mm
    • Ext.Z: 0 mm, 0 mm
    • Placement Disabled
  2. Create a 2D shape (Draft ShapeString or Sketcher sketch) on the XY plane
  3. Path->Job
  4. Select the 2D shape as model in the "Create Job" dialog
  5. Click OK
Result:
Job is not created and Job Edit panel is not shown
Error message
16:24:47    File "/.../freecad-build/Mod/Path/PathScripts/PathStock.py", line 222, in execute
16:24:47  ValueError: height of box too small
Workaround:
The key part is the Ext.Z parameter in Edit->Preferences->Path->Job Preferences->Setup.
Setting it to != 0 so the stock gets a height > 0 solves the issue
sliptonic
Post by sliptonic »
That makes sense and, in my opinion, is how it should work. with a 2D base object and a stock of 0 height the stock object can't control safe heights or retraction. If you're engraving something, how high would you expect the tool to retract between segments?
I suppose we could catch the error more elegantly and just not generate a path. What should be the correct behavior?
