Bug? Model doesn't follow stock
tigermm
Post by tigermm »
HI All,
I'm trying to profile the "cut arms" on the attached model but I can't for the life of me get it to work.
If I change the Z axis in the Job edit>Setup tab then the stock moves to the correct orientation, but the model doesn't follow it so it ends up profiling the end view of the model.
Am I doing this wrong (I presume so) or is it a bug?
Thanks,
Mike.
OS: Windows 10 Version 2009
Version: 0.20.25306 (Git)
Hash: 5f5b3d9b67136edda1f6738f1a83154990f7839d
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/New Zealand (en_NZ)
Reverse error.FCStd
(110.82 KiB) Downloaded 47 times
Re: Bug? Model doesn't follow stock
Change the position of "Model-Cut Arm" and let the stock follow.
tigermm
Post by tigermm »
Bah, why didn't I think of that!
Works now, thank you.
Interestingly when I selected transform to move it, no arrows appeared. I had to do it "manually" in the properties.
bmsaus4ax
Post by bmsaus4ax »
tigermm wrote: Thu Sep 23, 2021 11:10 pm HI All,
Did you select the face you want to be facing up for Z-axis, then select Z-Axis ? ( I find I have to have CAD navigation style selected to get good results with selection) Then click "Refresh" to update stock position, and exit with "OK" to save.
This worked for me with your file.
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.25645 (Git) AppImage
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
tigermm wrote: Fri Sep 24, 2021 12:34 am Interestingly when I selected transform to move it, no arrows appeared. I had to do it "manually" in the properties.
You're welcome.
I can confirm the missing transform tool and have no idea why that's the case, because normally clones can be moved like that.
