Profile compensation issue
skal
Post by skal »
I don't if this is how it should work, but I found that when trying to profile a contour using compensation, there's a bug in the GCode generation.
I created a piece 150mm*150m0*1mm that I planned to profile with a 2mm tool diameter.
I have the following settings:
2021-09-27 09_16_06-Window.png (6.87 KiB) Viewed 1424 times
And the generated code starts with:
G0 Z6.000
G0 X150.707 Y150.707
G0 Z4.000
G1 X150.707 Y150.707 Z-1.000 F900.000
G2 X151.000 Y150.000 Z-1.000 I-0.707 J-0.707 K0.000 F900.000
I don't understand why the first generated G1 command is to 150.707 and not 151.000.
Any idea ?
I have the following Freecad installation:
OS: Windows 10 (10.0)
Version: 0.20.25645 (Git)
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Locale: French/France (fr_FR)
testProfile.FCStd
(17.54 KiB) Downloaded 34 times
Re: Profile compensation issue
You may have to adjust the precision settings in the Path preferences.
GeneFC
Post by GeneFC »
skal wrote: Mon Sep 27, 2021 7:25 am Any idea ?
This is normal. Look closely and you will see that the path is starting on a rounded corner.
The standard path for a rectangle always "rolls around the corner" instead of making sharp turns. The end result will be perfectly sharp, however.
This fooled me at first, many years ago, but it works fine.
Gene
skal
Post by skal »
2021-09-27 17_05_15-Window.png (2.89 KiB) Viewed 1235 times
Thanks for the clarification, it make more sense now ;-)
