Path Simulator Errors
bmsaus4ax
Post by bmsaus4ax »
I have been receiving two different errors related to the Path Simulator with the last two updates to the 0.20 AppImage.
One is per the traceback below:
I occurs if a file is closed but FreeCAD not closed. When the next file is opened an attempt to run the Path Simulator throws up this error. The just closed file included.
If FreeCAD is closed fully and restarted the Path Simulator will run.
Running the Python command 'Path_Simulator' failed:
  File "/tmp/.mount_FreeCA5hc2y5/usr/Mod/Path/PathScripts/PathSimulatorGui.py", line 588, in Activated
    pathSimulation.Activate()
  File "/tmp/.mount_FreeCA5hc2y5/usr/Mod/Path/PathScripts/PathSimulatorGui.py", line 103, in Activate
    self.onJobChange()
  File "/tmp/.mount_FreeCA5hc2y5/usr/Mod/Path/PathScripts/PathSimulatorGui.py", line 459, in onJobChange
    for op in j.Operations.OutList:
Cannot access attribute 'Operations' of deleted object
The Second error I do not have an example for as yet ; but when a Simulation is called the Dialog opens , but choosing a job in the drop down does not show an Operation to run. There has been a CutMaterial Stock shown but not for the desired operation.
Again fully closing out of FreeCAD and restarting allows normal operation.
Versions:
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.25943 (Git) AppImage
Hash: a65464b722a846bd2999aa2fecdff1132b15b297
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
Version: 0.20.25997 (Git) AppImage
Hash: 77b198048a63f1e9ca15eef64c8042d599a14cf3
Qt version: 5.12.9
OCC version: 7.5.2
