I just pulled a fresh copy of master a couple of days back and knocked up a simple plate with four holes in it.
I added a drill path which did not select "peck" option.
When I look at the output I'm getting an air cut G80 down to stock; G0 to safe-height, then a G81cutting the same hole in the air hole before actually cutting the metal.
This is obviously a gross waste of machine time and seems rather confused. Why is it mixing G80 and G81 to get this job done?
This does not seem right. What is going on ?
Thanks.
OS: Fedora 34 (Thirty Four) (LXQt//usr/share/xsessions/lxqt)
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.15.2
OCC version: 7.5.0
confused drilling path
- ipn-holes-peck.txt
- (1.18 KiB) Downloaded 25 times
- pecked-holes.FCStd
- (23.89 KiB) Downloaded 29 times
Re: confused drilling path
Drilling used to work perfectly. I used it for thousands of holes.
A little more than two years ago someone had a problem when trying to drill a bunch of holes on a non-planar surface, all while using a single G81 operation. Broken tools and damaged material.
The solution was to kill the canned operation (G81) after every hole by adding a G80 cancel command. Extra hops up to the Clearance height were also added.
I argued quite strenuously against this silliness, but I lost.
I now have a modified postprocessor that removes all G80 commands. They are never really needed, since any motion command, such as G1, will cancel the G81 canned operation.
Gene
Thanks Gene. So it's a case of broke by design
I recall a discussion about a year about safe ht vs clearance ht, which seems to have the same root problem of not doing things the right for some distorted logic. I think it fizzled out and it just got dropped.
Could you post you post processor or PM me? That could save me some time writing it. This just taking a stupid amount of time cutting air.
Thanks for confirming it was not just me looking at it backwards.
Sorry, I did not remember my final solution correctly. I changed the PathDrilling.py instead of the postprocessor.
I removed:
I tried several things and ended up with this solution. I have not needed to drill a large number of holes lately so I forgot what I did.
Gene
I removed:
# Cancel canned drilling cycle
self.commandlist.append(Path.Command('G80'))
self.commandlist.append(Path.Command('G0', {'Z': obj.SafeHeight.Value}))
Gene
Brilliant , that saved me lots of time. Since I'm building from src anyway, that's just a tweek I have to put in each time.
Thx.
Thx.
Just make sure you check that the resulting path is sensible.
Gene
Gene
OK, I'll only say it was your fault if it goes badly wrong and I need someone else to blame
