Hello all,
I would like to mill a ring with two depths. Can anyone give me a tip on how I can save myself from having to mill the whole plane?
Here is the file:
Thanks in advance
Yours
Arne
[solved] Expensive Milling
Re: Expensive Milling
In the "Base Geometry" tab , select the inner vertical face as well. Although it does not get machined it limits the face that does.
If you need to machine the vertical face ( diameter ) you could use profile, assuming the hole already exists.
- faceSelected.png (36.83 KiB) Viewed 1404 times
Hello bmsaus4ax,
thank you very much for the tip.
Unfortunately, that didn't work for me at first. I inserted the two faces in the "Base Geometry" tab and pressed Apply. The result was unchanged:
You sent a screenshot which showed that it works. So I stuck hard and I changed the parameters and came up with the following correlation.
If I change the "Step over Percent" from 50 to 75 it suddenly works:
With a "Step over Percent" of 50 and a different tool controller it worked then:
I am satisfied with this at this time but call attention to the problem here.
I could prove the behavior with FreeCat 0.19 (Community) and FreeCat 0.20 (appImage) under ManjaroLinux.
Yours
Arne
p.s.: Details to used versions of FreeCat
OS: Manjaro Linux (KDE/plasma)
Version: 0.19.24291 (Git)
Branch: makepkg
Python version: 3.9.6
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Version: 0.20.26155 (Git) AppImage
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Yours
Arne
Branch: makepkg
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Qt version: 5.12.9
OCC version: 7.5.3
