Finishing pass with the Helix toolpath?
Giulio Buccini
Post by Giulio Buccini »
I adore the helix tool to make circular holes in my alu-plates. It is a pleasure watching the machne making the holes in this way! :D
Now I'm trying to understand why sometimes I get an (almost) perfect diameter of the holes, and sometimes not (around 0.1mm smaller diameter).
I'm preparing a test-plate to test the different approaches (helix vs traditional cylindrical cut / CW vs CCW / etc).
My question:
there is a way to to make a rough pass followed by a finishing pass with the helix tool?
Any trick/workaround?
(AFAIK there is only the step-over parameter available... :( )
OS: Ubuntu 16.04.7 LTS (XFCE/xfce)
Version: 0.20.25943 (Git) AppImage
Hash: a65464b722a846bd2999aa2fecdff1132b15b297
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
GeneFC
Re: Finishing pass with the Helix toolpath?
Post by GeneFC »
Make sure that the preferences are set correctly.
Edit >> Preferences >> Path >> Job Preferences >> Default Geometry Tolerance and Default Curve Accuracy
I cannot tell you what they should be for you application, but try something tighter and see if the hole diameter behavior changes.
You might also look in the Properties panel (below the Combo tree) for the Helix to make sure the various numbers look OK. Right click and select "Show All" to see all available parameters.
Gene
Giulio Buccini
Hi GeneFC,
preference settings are ok: Default Geometry Tolerance = Default Curve Accuracy = 0.0001 mm
Also, I didn't find any useful property of the Helix-op to set some offset, even by using the "Show All" command.
As workaround, I will make first a rough pass by using the Profile command. Then I will use the Helix command as finishing pass.
I'm curious to find the reason of this erratic behaviour: some plates with the same nominal diameter of 5 mm have a resulting hole of 4.98-4.99 diameter on some shapes, while on other shapes/jobs my caliper give me 4.88-4.89 mm of dia.
Obviously, I'm milling the same material, with the same speed and feeds, the same machine and the same Mach3 settings and the same working offsets...
I would obtain a reasonable accuracy of the holes to use precision-dowel for flipping the shape on the working table more precise. (I need to make some milling on the backside too.)
