Path Workbench: Engrave imported DXF
HWe
Post by HWe »
Hi all,
I am trying to create G-code for an imported DXF of a angel-drawing for engraving or pocket milling.
I managed to import the DXF into draft-workbench, create a compound, scale it and convert it into a sketch.
I used the sketch validation tool to connect points, etc.
When I try to either generate a path to engrave the 2D-sketch, or try to generate a pocket into a solid, the path-job does not create any proper pathes. I can create proper pathes to engrave or pocket-out text with the draft shape-strings.
What am I doing wrong - is the sketch not properly set-up ?
Any help is appreciated.
Attached please find my freecad-design.
OS: Ubuntu 20.04.2 LTS
Version: 0.18.4.
Python version: 3.8.2
Qt version: 5.12.5
bmsaus4ax
Re: Path Workbench: Engrave imported DXF
Post by bmsaus4ax »
HWe wrote: Sun Oct 24, 2021 10:47 am
Hi HWe,
The attachment did not get included in your post, try to send again.
It should be visible as a file name in the "Preview" before you select "Submit"
