'z_finish_step must be less than step_down' ??
freman
Post by freman »
I'm trying to do what seems like a fairly simple profile path. Starts at -2mm, steps 1mm and ends are -11.75mm
Expecting passes at minus 2 and each mm until minus 11, and a finish at 11.75 mm
Why is this creating an internal problem finding the last step? To me that seems to be 0.75mm which is indeed less than step_down
Bug ??
TIA
_customDepthParams
    cdp = PathUtils.depth_params(
  File "~/freecad-build/Mod/Path/PathScripts/PathUtils.py", line 792, in __init__
    raise ValueError('z_finish_step must be less than step_down')
<class 'ValueError'>: z_finish_step must be less than step_down
OS: Fedora 34 (Thirty Four) (LXQt//usr/share/xsessions/lxqt)
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.15.2
OCC version: 7.5.0
sliptonic
Re: 'z_finish_step must be less than step_down' ??
Post by sliptonic »
Stepdown shouldn't be a negative number. If that was computed automatically, there's a bug somewhere.
freman
Post by freman »
Ah thanks, a step down of plus one mm.
I should have spotted that. I've done enough of these paths.
I edited by hand , rubbed whatever was there and then went with the logic of negative space.
IMO, that should have been caught earlier. Either the input widget ( which won't even let me enter "12." instead of 12.0 ) could block negatives. Alternatively, since positive step would never seem to make sense it should be trapped before it confuses the algo.
Just before where it barfed, it could check for a positive number and either invert negatives or throw a meaningful message about negative steps instead the the cryptic thing it does show.
That this is the step magnitude rather than the step seems a bit confused but we're stuck with that now to prevent breaking everyone's files.
Quietly multiplying by -1 would be simplest. Though trapping incorrect input when it is done would seem best.
sliptonic
Post by sliptonic »
It needs to be addressed in a couple places. The task panel shouldn't allow a negative input. The property also shouldn't because the user might input the value from the property pane or use an expression that evaluates to a negative number. Then the depthparams object should test and raise an exception for a negative value. This because it might be used in user scripts.
sliptonic
Post by sliptonic »
the depth_params helper object already switches all the values to positive integers. However, it tests and raises this particular error first. I'll fix that one if you want to focus on the UI side.
