Clearing from stock outline
MRx
Post by MRx »
https://www.youtube.com/watch?v=FVx9jsqAkds&t=439s
I guess that is not possible with the path scripts right now no?
Mastercam clears the surface from the stock outline.
(screenshots are from the youtube video)
I feel like this lead in is not bad.
multi-passes:
There I am now:
Screen Recording 2021-11-29 at 16.31.46 (1).gif (432.73 KiB) Viewed 1858 times
Re: Clearing from stock outline
You can use two jobs for this.
MRx
Post by MRx »
I wonder what do you mean with 2 jobs?
I moreover think about adding this feature to the outline function actually.
The outline feature itself supports an offset, just call the function in a loop, add the offset and maybe add that stub at the edge of it.
MRx
Post by MRx »
I just did some tests, and seems like I just need to call area.makeSections multiple times in PathAreaOp.py to generate multiple passes (certainly some sorting etc. has to be done). another interesting option would be the lead-in from outside.
        sections = area.makeSections(mode=0, project=self.areaOpUseProjection(obj), heights=heights)
        areaParams['Offset']=10
        area.setParams(**areaParams)
        obj.AreaParams = str(area.getParams())
        sections2 = area.makeSections(mode=0, project=self.areaOpUseProjection(obj), heights=heights)
        PathLog.debug("sections = %s" % sections)
        shapelist = [sec.getShape() for sec in sections]
        shapelist+=[sec.getShape() for sec in sections2]
chrisb wrote: Fri Nov 26, 2021 8:00 am You can use two jobs for this.
You asked by PM what this means. I can see nothing private in such a question and others may wonder too: I mean one Path Job object for the bigger right part and another Path Job for the left part. This wouldn't work by level, but rather depth-first. Which means that you have one additional vertical move and depending on the start point one horizontal.
MRx
Post by MRx »
ah, yes I know what you mean that would work but I'm looking for something else - something quicker and only climb cutting, even adaptive is doing a lot "air"cuts since I have many small edges.
I have updated the thread in the meanwhile so I wasn't sure if you got the update (that's why you got the PM)
I'm looking for the exact same path movement:
https://www.youtube.com/watch?v=sdeSVnuJwNM
I want to clear my object completely from the outside to avoid having to use a 6mm endmill for small slots, that's the result of my current modification:
this object is just a sample used for programming.
I'm having a look at a different lead in option now, I want to attack the object completely from outside also without unnecessary retractions
sliptonic
Post by sliptonic »
This is a feature I'd like to implement. It wouldn't be very difficult and extremely useful for clearing large side voids in a profile. This is exactly the kind of feature that would be easier to implement once we extract the command (gcode) out to individual generators.
It's exactly the kind of feature I don't want to implement until then.
But if you want to work on the generator, we can talk.
MRx
Post by MRx »
Indeed so far it was easy..
Now I need to add some clipping and the horizontal lead in to remove the plunging
Small update, it takes the stock outline as reference (and there's a stock outline extension):
Next step fixing the lead in for this path
Next step transforming the generated and sorted Wire to a path (and hope that it won't cut anything off there)
- The start-point is currently wrong
Screen Recording 2021-11-29 at 16.31.46 (1).gif (432.73 KiB) Viewed 1886 times
first test.
