Path counterclockwise for engraving?
Hi all,
when selecting the segments/arcs for an engraving operation, Freecad-Path always generate toolpath in the clockwise direction, no matter what I do to convince him to go in the counterclockwise direction instead:
Any idea how I could reverse the path direction?
P.S.
I already tried to select the edges one by one in counterclockwise direction, as well as directly drawing the edges counterclockwise by using the sketch editor.
P.S.
Re: Path counterclockwise for engraving?
A preferably very simple file showing the issue helps the helpers to fiddle with the options. I would start trying to move the start point.
Here the sketch I used for testing.
(Open or closed path exhibits the same behaviour.)
- engrave-test.FCStd
- (17.09 KiB) Downloaded 36 times
It has a start vertex instead - which does rather fancy things if the path is not closed:
- SnipScreenshot-904a81.png (10.36 KiB) Viewed 2345 times
I do not understand... choosing a different start-vertex works for closed paths instead?
(AFAIR, I tried this trick and was not working for open or closed paths both.)
Setting the start vertex for closed loops works perfectly here.
OS: macOS 10.16
Version: 0.20.26375 (Git)
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
Hi Chris,
for me doesn't work. I've set the start vertex at #8, but the path direction is still clockwise, not counterclockwise.
OS: Ubuntu 16.04.7 LTS (XFCE/xfce)
Version: 0.20.26375 (Git) AppImage
Branch: (HEAD detached at 8a6e3d1)
Hash: 8a6e3d1b766a34546806b22d750929c2d00e30a6
Qt version: 5.12.9
OCC version: 7.5.3
Qt version: 5.12.9
OCC version: 7.5.3
You have 8 vertices, and the default is 0, thus the last would be 7.
- sliptonic
Just curious. What's the use case here? For an on-line operation like engraving climb/conventional is irrelevant. Why does the path need to go a specific direction?
