Toolpath too low. Why ?
supik007
Post by supik007 »
Hello all!
I'm trying to create PATH and export to GRBL file for hobby 3018. All is OK, but generated path (begin lines of path) is too low. I don't know what I'm doing wrong...
create simple object
create Job
create Faces
and create Contour
Then create Post Procesing. and see in code : (preview )
(begin operation: Profile_Faces)
(Path: Profile_Faces)
(Profile_Faces)
(Compensated Tool Path. Diameter: 0.8)
G0 Z5.0000
G0
G0 Z0.0000
G1 X72.0060 Y1.9229 Z-0.8000 F60.00
G2 X72.0986 Y2.0590 Z-0.8000 I0.1408 J0.0038 F60.00
At the third line from end you see tool is lowering at 0 - here is material.. But then tool goes to "window" - and lowers at -0.8mm.
Right is move to window position and then lower at -0.8.
Where is my mistake ?
Thanks.
as attachment is my test file ....
displej.FCStd
(26.96 KiB) Downloaded 18 times
sliptonic
Re: Toolpath too low. Why ?
Post by sliptonic »
Please read the post about asking good questions. Then update your post with your FreeCAD info.
I took a quick look at your file and it looks like it might be created with an old version of FreeCAD. I tried a new profile and it generated correctly.
spanner888
Post by spanner888 »
I opened your file, but had a number of errors, which I suspect may be due to using a different FreeCAD version. One error I see is that the Path job has no model.
We need to know your FreeCAD info as described at point 4 in this forum info.
Then people helping can try your FreeCAD version and avoid any version differences.
EDIT: @sliptonic posted while i was typing ...
The file was made with 0.18.
supik007
Post by supik007 »
Yes, I use openSuse, and new 0.19 version of FreeCAd is unavailiabe yet.
OS: openSUSE Leap 15.2
Version: 0.18.Unknown
Python version: 3.6.10
Qt version: 5.12.7
Coin version: 3.1.3
Locale: Czech/Czech Republic (cs_CZ)
I again watch video with example how to use job tool. Delete old job and create new, as I see in video. Surprisingly path is right now ... but I change my tool to endmil. I don't know what I was wrong,
Many times I tried it, so maybe I was deleted model, as said spanner, do not know...
Now path looks ok :
(Contour)
G0 Z5.0000
G0 X142.6893 Y56.9685
G0 Z3.0000
G1 X142.6893 Y56.9685 Z-0.8000 F60.00
G2 X142.8064 Y56.6857 Z-0.8000 I-0.2828 J-0.2828 F60.00
Thank you for your effort, the problem seems to be solved.
M.
