Path OPs don't work with translated UI
Re: Path OPs don't work with translated UI
I recently changed the translation extraction code, it's possible those strings were not being made available for translation before due to a mistake in the old way of determining whether to extract C++ or Python translation strings.
Can you link a specific example so I can see what you mean? We've avoided the issue elsewhere by strictly separating UI lists from their corresponding program logic. This is often accomplished by relying on, for example, the index of the item rather than its text, but often a better approach is to attach "user data" to each UI element. That's almost always my approach in C++, but I haven't really tried it in Python.
In my mind 2 possible reasons:
1. The enumerations were not in crowdin
2. If they were, no one translated it...
Gruß Herbert
But in 0.19 and initial 0.20 code if you assign a .Name property not starting with "Job” some actions were not triggered.
Maybe this behaviour is different now, but in the past when I was scripting Path I have noted this.
Sorry if it is not related.
Regards
Carlo D.
Regards
Carlo D.
- Various other stuffs.
OK, I took a closer look at this particular example. First, I'm relatively certain that the answer to "why was this never a problem before?" is because there used to be a bug in the translation extraction code that was causing these UI files to be skipped. That's been fixed, and they are now translatable, as all UI files should be by default. That recent translation merge was done just after the change to the extraction script, so the new translations aren't due to overzealous translators: they are doing exactly what they should be doing, translating all user interface strings.
So, the problem is that fundamentally this line:
is not a good practice. It's depending on the exact user interface text meaning something programmatically, which is generally inadvisable (in part for exactly this reason). In my opinion the best solution is to attach extra data to each UI element, and instead of using "currentText" (the user-visible string) use "currentData" (the invisible value that the program requires internally). You could also use the index directly, if you know that the order of the elements is stable, but I personally have found that to be more code in the long run, if you have to do this in more than one place.
In this particular case you would have something along the lines of:
obj.Side = str(self.form.cutSide.currentText())
def getForm(self):
'''getForm() ... returns UI customized according to profileFeatures()'''
form = FreeCADGui.PySideUic.loadUi(":/panels/PageOpProfileFullEdit.ui")
form.cutSide.setItemData(0, "Outside") # Does NOT change the displayed text
form.cutSide.setItemData(1, "Inside")
return form
def getFields(self, obj):
'''getFields(obj) ... transfers values from UI to obj's proprties'''
self.updateToolController(obj, self.form.toolController)
self.updateCoolant(obj, self.form.coolantController)
if obj.Side != str(self.form.cutSide.currentData()): #Uses the data stored in Qt.UserRole
obj.Side = str(self.form.cutSide.currentData())
- sliptonic
I've created a PR to resolve this based on chennes's ideas.
It goes a bit farther and clears the combobox contents when the forms are loaded and then populates them with the strings. This means all the string literals are defined in the code and the code ignores any literals that are in the .UI files. At some point, we should go back to the .UI files and replace the text there with 'PLACEHOLDER' or something so future developers don't waste their time. I've left them for now because it's probably easier to troubleshoot if I made a mistake somewhere.
The changes are a lot of cut-n-paste but this PR touches a LOT of files so I'd appreciate some testers.
https://github.com/FreeCAD/FreeCAD/pull/5242
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.
Branch: unknown
Hash: e54b6e167a5d5ab863e8d4db68e4add65b1525ba
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
Since the last update I'm experiencing the above mentioned problem also in the English UI. But only for the 'slot' Operation. If I want to create a slot e.g. on the attached file, I get the following error:
16:46:18 Running the Python command 'Path_Slot' failed:
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 1440, in Activated
return Create(self.res)
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 1402, in Create
obj = res.objFactory(res.name, obj=None, parentJob=res.job)
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathSlot.py", line 1774, in Create
obj.Proxy = ObjectSlot(obj, name, parentJob)
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathOp.py", line 351, in __init__
job = self.setDefaultValues(obj)
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathOp.py", line 576, in setDefaultValues
obj.CoolantMode = job.SetupSheet.CoolantMode
'Flood' is not part of the enumeration in Unnamed#Slot.CoolantMode
I'm sorry, if that is not related to the problem described in this topic - If so, I will create a new topic.
Any help greatly appreciated because many of my files I need on a daily basis contain slot operations
Version: 0.20.
Branch: unknown
Qt version: 5.12.8
OCC version: 7.5.2
- Slot_Bug_Example_1.FCStd
- (27.7 KiB) Downloaded 13 times
PartDesign Sprocket... has an enumeration problem, too:
Bicycle with Derailleur and Bicycle without Derailleur must not be translated and I have made a new suggestion in Crowdin in the meantime. Since there hasn't been any voting the new "translations" are on top of the list and used in the UI.
Motorrad... is still false and needs correction back to Motorcycle...
- sliptonic
Slot is the only operation that hasn't been completed for the translation cleanup project. It's kinda hairy code and I asked @Russ4262 to help out.
Evening Sir.
I just submitted a PR with what I believe to be the fix for translation issues within this operation, Path: Fix Slot operation translation issue #6340.
Thanks for your patience and tremendous contributions.
Russell
