What are your opinions?
File "/usr/lib/freecad/Mod/Path/PathScripts/PathJobGui.py", line 133, in attach
self.axs = coin.SoType.fromName("SoAxisCrossKit").createInstance()
File "/usr/lib/python3.10/site-packages/pivy/coin.py", line 491, in createInstance
return _coin.SoType_createInstance(self)
<class 'SystemError'>: <built-in function SoType_createInstance> returned a result with an exception set
PathJobGui.ERROR: <built-in function SoFieldContainer_getField> returned a result with an exception set
SystemError: PY_SSIZE_T_CLEAN macro must be defined for '#' formats
The above exception was the direct cause of the following exception:
File "/usr/lib/freecad/Mod/Path/PathScripts/PathJobGui.py", line 1565, in Create
obj.ViewObject.Proxy.editObject(obj.Stock)
File "/usr/lib/freecad/Mod/Path/PathScripts/PathJobGui.py", line 194, in editObject
return self.openTaskPanel("Stock")
File "/usr/lib/freecad/Mod/Path/PathScripts/PathJobGui.py", line 178, in openTaskPanel
self.showOriginAxis(True)
File "/usr/lib/freecad/Mod/Path/PathScripts/PathJobGui.py", line 156, in showOriginAxis
self.switch.whichChild = sw
File "/usr/lib/python3.10/site-packages/pivy/coin.py", line 3998, in __setattr__
field = self.getField(name)
File "/usr/lib/python3.10/site-packages/pivy/coin.py", line 3873, in getField
return _coin.SoFieldContainer_getField(self, name)
SystemError: <built-in function SoFieldContainer_getField> returned a result with an exception set
File "/usr/lib/freecad/Mod/Path/PathScripts/PathJobGui.py", line 667, in accept
self.preCleanup()
File "/usr/lib/freecad/Mod/Path/PathScripts/PathJobGui.py", line 662, in preCleanup
self.vproxy.resetEditVisibility(self.obj)
File "/usr/lib/freecad/Mod/Path/PathScripts/PathJobGui.py", line 273, in resetEditVisibility
for base in obj.Model.Group:
<class 'ReferenceError'>: Cannot access attribute 'Model' of deleted object
