Ticket #4817 - CAM Simulator fails
anka
Post by anka »
Hi all,
trying to run cam simulation gets following error :
Running the Python command 'Path_Simulator' failed:
  File "/Applications/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathSimulatorGui.py", line 588, in Activated
    pathSimulation.Activate()
  File "/Applications/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathSimulatorGui.py", line 103, in Activate
    self.onJobChange()
  File "/Applications/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/PathSimulatorGui.py", line 459, in onJobChange
    for op in j.Operations.OutList:
Cannot access attribute 'Operations' of deleted object
Up to version 0.20 FreeCAD_weekly-builds-26554-OSX-x86_64-conda, cam simulation worked ok.
Anyone an idea ?
Tnx, AK
OS: macOS 10.16
Version: 0.20.26720 (Git)
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
Reason: Added ticket number to thread title
Re: CAM Simulator fails
It looks as if you have somehow scrambled your Job, but it's hard to say without the file. The crystal ball is still out for service to be in perfect condition for the next year's predictions.
bmsaus4ax
Post by bmsaus4ax »
anka wrote: Fri Dec 31, 2021 4:45 am Hi all,
Anyone an idea ?
Tnx, AK
This happens for me if I close a file and then reopen it, or any other file, without closing completely out of FreeCAD.
Once a file has been closed no further attempts at simulation run.
If you completely close the program and open a new copy , simulation will then work without error.
Although the attached version info is the latest this has been happening for a few versions.
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.26720 (Git) AppImage
Branch: (HEAD detached at 7bca26e)
Hash: 7bca26e7c14d4d43374ff7e0c8582735b249cbfd
Qt version: 5.12.9
OCC version: 7.5.3
sliptonic
Post by sliptonic »
bmsaus4ax wrote: Fri Dec 31, 2021 9:25 pm
Neat. If this is reproducible, please open a ticket.
bmsaus4ax
Post by bmsaus4ax »
sliptonic wrote: Tue Jan 04, 2022 3:15 pm
Still working on how to do the create ticket.
Tested back through saved AppImages and find it starts with 25541 (Conda )
Version: 0.20.25541 (Git) AppImage
Hash: ca043dcb6d20d70b8e24d75e810683214eecc5d4
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
This appears to be aligned with the commit on August 14, 2021. Russ4262
Change involves : jobList = FreeCAD.ActiveDocument.findObjects("Path::FeaturePython", "Job.*")
is taken out of "def Activate(self)"
and " def _populateJobSelection(self, form):" is created
https://github.com/FreeCAD/FreeCAD/comm ... ba2ae4debd
The error points to the lines numbers involved in this.
Russ4262
Post by Russ4262 »
Thanks for finding.
Thanks for reporting.
Thanks for fixing.
Russell
bmsaus4ax
Post by bmsaus4ax »
Russ4262 wrote: Fri Jan 07, 2022 6:02 pm Thanks for finding.
Thanks for fixing.
Russell
Fix tested and confirmed as of AppImage update: Version: 0.20.27078 (Git) AppImage
Thank you.
Branch: (HEAD detached at bcdd926)
Hash: bcdd926686f2245fe60baface1cce1ab3dff7a5b
Qt version: 5.12.9
OCC version: 7.5.3
Re: Ticket #4817 - CAM Simulator fails
Post by Kunda1 »
Closing issue #4817 in that case
