issue with a translation of command on the GUI
david69
Post by david69 »
I think there is a mismatch in the code for the following command "Pocket Shape" which forbids the translation. I am using Yorik's advices
if we run the command from the GUI, we read in the Python view:
>>> Gui.runCommand('Path_Pocket_Shape',0)
and if I look for the code, I find:
dvd@dvd:/usr/share/freecad-daily$ grep -r "Pocket Shape" *
Mod/Path/PathScripts/PathPocketShapeGui.py:__title__ = "Path Pocket Shape Operation UI"
Mod/Path/PathScripts/PathPocketShapeGui.py:__doc__ = "Pocket Shape operation page controller and command implementation."
Mod/Path/PathScripts/PathPocketShapeGui.py:Command = PathOpGui.SetupOperation('Pocket Shape',
Mod/Path/PathScripts/PathPocketShapeGui.py:        QtCore.QT_TRANSLATE_NOOP("Path_Pocket", "Pocket Shape"),
Mod/Path/PathScripts/PathPocketShape.py:__title__ = "Path Pocket Shape Operation"
Mod/Path/PathScripts/PathSelection.py:    opsel['Pocket Shape'] = pocketselect
in particular
Am I well understanding? Can it explain why we don't see the translation even if in Crowdin there is one for a while.
I am not yet familiar with these actions.
sliptonic
Re: issue with a translation of command on the GUI
Post by sliptonic »
There's lots of issues with use of translation in Path. We've got an organized effort underway to fix it.
https://github.com/sliptonic/FreeCAD/wi ... up-Project
That wiki page links to others that explain translation pretty well.
One PR has already been merged and two more (#5324 #5270) are pending. If you want to help with the cleanup, that page will get you started or ping me on gitter.
david69
Post by david69 »
thank you for the answer and your suggestion to participate to fix these issue on Path workbench.
I have translated almost all the wiki in French and also giving a hand on Crowdin (that's the way I have found "my" small issue). Code is far from my knowledge but if I can spend some time on that, I'll give a try.
david69
Post by david69 »
@Sliptonic, I have pm you through the forum. I don't have account on gitter and don't want.
sliptonic
Post by sliptonic »
david69 wrote: Sun Jan 16, 2022 10:16 am @Sliptonic, I have pm you through the forum. I don't have account on gitter and don't want.
I didn't get a pm. Please resend
