I'm trying to minimize tool changes in a Job, so I like the sound of Order By = Tool. But I can't get it to work how I'd like, and I can't figure out what I'm missing.
This Job has Ops with different Tool Controllers in no particular order. Example:
- Op 1: TC 1
- Op 2: TC 2
- Op 3: TC 1
- etc. etc.
The job is set to order by Tool. But the GCode produced still starts with TC 1, then switches to TC 2, then back to TC 1.
Any ideas what I'm doing wrong or how I could troubleshoot this?
Thanks!
Path Order By Tool
Re: Path Order By Tool
Use 0.20. If it doesn't work, upload a simple file showing the issue.
Sure, here's a simple example that demonstrates it.
There are 3 ops, using TC 1, 2, then 1 again. The job is created with mostly default settings (changed postprocessor to grbl). TC1 is "1/4 Endmill" and TC2 is "1/8 Endmill".
Snippets from the gcode produced are copied below showing how it goes from TC1 -> TC2 -> TC1, despite orderby=tool.
Please let me know if any other info would be helpful to diagnose it, or if it looks like I'm doing something wrong to prevent it ordering by TC.
Thanks again!
(Begin preamble)
(Begin operation: 1/4 Endmill001)
(Begin toolchange)
(Begin operation: Fixture)
(Begin operation: Op 1 TC 1)
(Begin operation: 1/8 Endmill001)
(Begin toolchange)
(Begin operation: Op 2 TC 2)
(Begin toolchange)
(Begin operation: Op 3 TC 1)
(Begin postamble)
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.26912 (Git)
Hash: 6aec424aa52a9c23a6327d78d931f547a60507ca
Python version: 3.8.10
Qt version: 5.12.8
Thanks again!
(Begin preamble)
(Begin toolchange)
(Begin toolchange)
(Begin toolchange)
(Begin postamble)
Qt version: 5.12.8
- 1_8_Endmill.fctb
- (242 Bytes) Downloaded 18 times
- 1_4_Endmill.fctb
- (242 Bytes) Downloaded 22 times
- Path Orderby Tool Example.FCStd
- (23.26 KiB) Downloaded 20 times
- gcode.txt
- (3.22 KiB) Downloaded 25 times
- ops.png (36.3 KiB) Viewed 1478 times
I am not quite sure what you are doing. I loaded your file, went into Job Edit >> Workplan and then arranged the Ops by tool.
G-code came out as desired, with all Tool 1 first followed by Tool 2.
[Edit] OK, I dug a bit deeper. There is a hidden property that would seem to support order by tool. It did not work for me either. In fact it undid the Workplan order I had set in the Job Edit.
Gene
Gene
Ya, that's my backup plan- we can still manually set the order in the Operations list. But when there are a large number of Ops, it'd be nice to be able to keep the Ops list in an order that makes logical sense to me (easy to find what I'm looking for), but still produce gcode ordered by tool.
- sliptonic
The order of operations in the job takes precedent. Those should be ordered in the order you want the work done.
The 'order by tool' feature applies when you're doing the same work in multiple coordinate systems. First op will still be done before second op but it will move between WCS to minimize the tool changes.
You change the order of operations in the job in the workplan tab.
That makes sense, thanks for the info.
