Halfpipe becomes a bathtub in PATH 3D pocket
Mooney542
Post by Mooney542 »
Can't figure out how to Path this. When I run 3D path on a 6mm ball mill, I don't get a channel running clear through the part. Rather I get a "bathtub" with the two ends of the halfpipe closed. I need a milling profile to extend beyond the end of the pipes so the ends are cleared. I tried running this on the actual milling machine assuming the simulation program is not displaying properly, but apparently it is. I can't get a clean cut all the way through.
Halfpipe.FCStd
(128.13 KiB) Downloaded 27 times
OS: Windows 10 Version 2009
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Re: Halfpipe becomes a bathtub in PATH 3D pocket
Hi and welcome to the forum!
I don't think than 3DPocket can do that. Try 3DSurface with boundary adjustment set to 3mm (=diameter/2).
herbk
Post by herbk »
at similar parts i use Pocket 3D to remove the most material and as a secound stepp, like chrisb wrote, 3D Surface to do the finish.
Gruß Herbert
Mooney542
Post by Mooney542 »
THAT DID IT!! YES!!
Thanks for your assistance!
