Bug in Postprocessor?
strahlensauger
Post by strahlensauger »
I drew a model in FreeCAD and the path module created the toolpath correct.
The ngc file contains G3 commands with very great I and J Parameters, that linuxcnc interprets as big circles,
you can't see the shape of the door anymore and you have limit errors, because the circles are so big.
I attached the files.
Wichteltuer6a.FCStd
(811.05 KiB) Downloaded 23 times
In the gcode file "Wichteltuer.txt" in line 275 for example:
G3 X7.488 Y99.829 Z-6.340 I-2549472.509 J1456846.035 F1200.000
is this a bug or is my model bad?
OS: Arch Linux (xmonad)
Version: 0.20.27078 (Git) AppImage
Branch: (HEAD detached at bcdd926)
Hash: bcdd926686f2245fe60baface1cce1ab3dff7a5b
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
Wichteltuer.txt
(26.63 KiB) Downloaded 19 times
sliptonic
Re: Bug in Postprocessor?
Post by sliptonic »
Big IJ values aren't a problem. Those are offsets to center of the arc so if the arc has a large radius, you'll get big values.
The same values are present in the Path commands. I took your gcode and ran it through nc viewer and it renders correctly. Are you sure you don't have your machine set up for radius format arcs or something like that?
strahlensauger
Thank you for your quick answer.
As so often in computer programs I would say I'm sure the linuxcnc is not in radius format or arcs or sth like that.
But I was often wrong...
I checked with another test machine I have build with a raspberry pi and I checked it against the linuxcnc simulation program, which comes
preconfigured, same behaviour - no door just circles.
So I am pretty sure the problem is the linuxcnc interpreter of the gcode.
I will take the topic to the linuxcnc forum.
Thanks again for your support
strahlensauger
Your hint pointed me in the right direction.
In the gcode file at the beginning I changed G90 to G91.
Voila. Still there are 3 very big circles and an error message on the first encounter of the I and j parameter,
but I can see the model and can correct the couple of lines of code that causes trouble by hand.
Thx again
