Really simple question
OS: Windows 10 Version 2009
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Re: Really simple question
Hi and welcome to the forum!
Please retry with 0.20 and a Pocket using extensions:
- SnipScreenshot-cc7e1e.png (19.11 KiB) Viewed 1398 times
Many thanks - will upgrade and try again.
Now got it working on 0.20.
Still something odd going on. Zigzag and line cuts work as expected
But Sprial cut leaves waste in the middle
Anyhow - I will continue my journey of discovery - big thank you to the developers here.
Version: 0.20.26858 (Git)
Hash: e209bc706d35121098f9bac779bc6b09c24ddd95
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
You need to reduce the stepover. When set at 100% of the tool diameter there will always be uncut areas for anything but the simplest retangular shapes.
It also appears that the extension is too small. For these pointed corners a full tool diameter is needed, not the default half-diameter.
Gene
Subject is now not helpful - I will open a new post.
Having played around I am now convinced there is a bug in spiral pocket path with extensions. See new post for more details.
- sliptonic
A bunch of the patterns on pocket are really almost useless. I think we should disable all but the simplest ones. For a something like this, you really don't want a true spiral anyway. You want an adaptive. I would suggest trying the Adaptive operation with extension.
