Get the size of the stock in a custom postprocessor
thomas-huber
Post by thomas-huber »
Hello everybody.
I'm trying to write a post processor for our scm record 110 cnc maschine (xilog based).
So far progress is good, but im stuck with the following:
Programs for our cnc must include header-line where the size (height, width, depth) of the stock object is defined. In FreeCAD the stock geometry is defined with a Job but I can't figure out how to access it from withing the postprocessor. :?
Thank's in advance, please let me know if you need more information.
Best
Thomas
Re: Get the size of the stock in a custom postprocessor
It is too long ago that I programmed my postprocessor, and I'm sure that I didn't access the job at all. If you have access to the Job and it is stored in a variable called "job", then you can get the information you are looking for with
job.Stock.Shape.BoundBox
For a default 10x10x10 cube and a default job the result would be
BoundBox (-1, -1, -1, 11, 11, 11)
thomas-huber
Hi chrisb,
thank's for your answer.
The postprocessor's export function only gets a list of objects but not the job itself. So it was a bit tricky to access it.
Here is what I did:
    doc = None
    for obj in objectslist:
        if hasattr(obj, "Document"):
            doc = obj.Document
    box = doc.Job.Stock.Shape.BoundBox
It feels a like a hack, and it will not work if Job is named to something else, but it will do the trick for me.
dubstar-04
Post by dubstar-04 »
thomas-huber wrote: Thu Jan 27, 2022 10:16 am It feels a like a hack, and it will not work if Job is named to something else, but it will do the trick for me.
Is this any use:
https://github.com/FreeCAD/FreeCAD/blob ... ls.py#L393
Thanks,
Dan
thomas-huber
Oh thanks, that's perfect!
