Feeds and Speeds Addon
- dubstar-04
I'm pleased to announce that the feeds and speeds addon is now available via the FreeCAD Addon Manager.
Features:
- Select path tool controller
- Select workpiece material
- Select Tool Material
- Set machining parameters
- Write calculated feedrate and spindle speed to the selected tool controller
Please report any issues here or on github: https://github.com/dubstar-04/FeedsAndSpeeds
Features:
Re: Feeds and Speeds Addon
Very good work.
Regards
Carlo D.
Regards
Carlo D.
- Various other stuffs.
Thanks!
Thanks!
Great work. Intuitive, easy to use for a complete beginner. The live update of calculated values is especially nice. I had a few things I noticed though.
Why is the minimum chipload set at 0.0200? Is that set elsewhere, or an arbitrary minimum?
I was able to enter negative stepovers and stepdowns just with the down arrow key when the respective boxes were selected. Is a negative stepdown desired for things like 3-d printing, or is that handled elsewhere? I would think that, at least, the negative stepover would cause problems with the rest of Path.
I was also able to enter negative surface speeds as well. Does that mess up FreeCAD elsewhere?
I think that the power calculation should stop increasing when you exceed a stepover greater than the tool diameter.
Overall, excellent job. Thank you,
-Thomas
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.20.27008 (Git) AppImage
Branch: (HEAD detached at 9162733)
Hash: 91627338a44371fe9a8e815b4900f62558af98a1
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
Feeds and Speeds Addon:
v0.1.0
Installed via Addon Manager
-Thomas
Qt version: 5.12.9
OCC version: 7.5.3
v0.1.0
- Screenshot from 2022-01-27 22-13-38.png (60.23 KiB) Viewed 2720 times
- dubstar-04
In most tools is snowing to limit values, when make a research or experimenting with calculations, not limit but make a warning a tooltip or red alert
I would prefer a warning too. I have seen this quite often, that there occurred use cases where doing something "foolish" was exactly the right thing. And then it is a pain if somebody else has done all the thinking for me - except that special use case.
