[SOLVED] Cannot modify the step-over of the helix
sliptonic
Re: [SOLVED] Cannot modify the step-over of the helix
Post by sliptonic »
bmsaus4ax wrote: Mon May 16, 2022 3:01 am May need to modify the .ui file when integrated.
@ Default of Outside overwrites Def: of Inside in generator.
@ Percentage step over to 100% as default ? , 1% as at present too fine. Units mismatch?
@ CCW to default if Inside becomes default ?
Updated the PR. Default is now 50% stepover.
Default for the generator is now 'Outside'. This does not affect behavior in the GUI.
Thanks for the review. The initial small stepover to avoid the untouched center bump is possible. I don't want to touch it before release. We can revisit in 0.21
