[Solved] I can't generate a 3D pocket toolpath for half spheres
pathfinder
Post by pathfinder »
I can't generate a 3D pocket toolpath for half spheres and I wonder why.
I have a model that I'm working on, on which some, but not all pockets generated viable toolpaths. Some pockets were ignored, in others, just the top layer was generated, in some, in between layers were missing, others generated a toolpath on the bottom of the object, so straight through the object; so basically I had every possible bug in one operation. There is no functional difference between the pockets, they are all part of a linear pattern.
To investigate, I rebuilt the shape, but simpler. It is the file I attached. I can't generate any 3D pocket toolpaths on this one. I played around with cut patterns, different tools, different step downs, stepovers and so on. No dice.
Does anybody know why, and how I can work around these issues?
OS: Arch Linux (XFCE/xfce)
Version: 0.20.28810 (Git) AppImage
Branch: (HEAD detached at 6f5a5a2)
Hash: 6f5a5a2019c586db63650713de860d3e810739d4
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
TIA
Edit:
I did try one more time; this is what happens when I select none of the pocket faces:
As you can see, it does something, but not all pockets are cut properly.
Both 3D surface and Waterline work as they are intended, but have their own limitations.
holes.FCStd
(53.34 KiB) Downloaded 17 times
Re: I can't generate a 3D pocket toolpath for half spheres
pathfinder wrote: Sun May 15, 2022 5:46 pm and how I can work around these issues?
Did you try 3D Surface?
It seems to be a coplanar issue. If I lift the sketches of the grooves by 0.1mm it works as expected:
holes_cb.FCStd
(149.95 KiB) Downloaded 18 times
pathfinder
chrisb wrote: Sun May 15, 2022 10:45 pm It seems to be a coplanar issue.
Yup, solved, thanks.
Booleans being booleans I guess. I need to be more mindful of that.
Btw. 3D surface worked fine, as did waterline.
Now I need to find out how to create an offset on the pocket similar to BoundaryAdjustment from 3D surface. There is an offset you can set, but it doesn't seem to work in the z-direction.
pathfinder wrote: Mon May 16, 2022 1:19 am Now I need to find out how to create an offset on the pocket similar to BoundaryAdjustment from 3D surface. There is an offset you can set, but it doesn't seem to work in the z-direction.
An old mechanic told me what he does in such cases on a real machine: Fool it by pretending that you have a different tool. In your case it has to be a little bit longer.
pathfinder
chrisb wrote: Mon May 16, 2022 1:24 am
-___- My brain sometimes… As if I didn't do this exact thing last time. Thanks for the nudge, I guess.
